hi, could you say me if the motion sensor can act like a switch even if there is no motion detected ?
For exemple, using it with the zone and activate the some light when your smartphone is in the zone (even if you are not in the motion detect range) … but also using it like a normal motion sensor ?
The motion sensor is separate from the light, they are not connected to each other. The lights are turned on by an automation when motion is detected, but you can also turn on the light at a specific time, or when you are in a zone or whatever. However, you need either a smart light bulb or a smart light switch for this to work.
I never heard or saw any out-of-the-box device that does this AND can be connected to HA, DIY should be possible. Can you not make the light “smart” with a switch or bulb?
There are some behind the wall switches that can also connect a legacy switch. Most of them are rebranded/cloned(?) Sunricher devices. Mine works just fine with the conbee2 (using OpenZHA, not deconz).
However, as far as I have read, the connected switch does not make the device announce its new state via Zigbee, which makes it kind of uninteresting imho.
I keep hearing this but I don’t know if it’s true. I can personally say that I have Xiaomi lux sensors, multi sensors and window sensors. They all have no trouble at all with my IKEA bulbs or repeaters accessing my ConBee II
I’ve add my inner plug, but it seems that my Xiaomi sensor stay connected to the conbee, even if I’m pretty sure connection to the inner will be more powerful in range etc.
No, you can’t. You can try removing the sensor and turn off all mains powered devices except for the innr plug and pair again. If you are lucky it will route through the plug, but even if it does, it might as well change the next day, routes are dynamic.
I will try to remove the cell of my sensor … because one off my sensor is disconnected (far away from the Connect) but the cell are new… maybe make an on/off will connect it to the innr plug
