I have noticed the same issue with duplicated device, I have disabled the device without an assigned area. However I notice my Total Energy sensor is working but my Current Energy sensor isn’t. Has anyone else noticed similar before I raise an issue on GitHub.
I add 33 kWh today which shows in the Total Energy when the session ended but I have a flat line on my Current Energy sensor today.
My Current Energy is often below the actual consumption, but it’s the same in the Pod Point app so I don’t think there’s much Matt can do about that in the integration.
Hi, could any help me create a button that calls the Charge Now service, but accepts an input for the hours to charge for via the UI? I’d like a Charge Now button on my wall panel, I can see the service needs time inputs, but I need something that my better half can just initiate from the wall panel and input the hours. I don’t want to charge till full as we’re on Octopus Agile and will want say 4 or 5 hours during the day. Thanks.
After updating to v2.0.4 (unsure of previous version) the Pod Point device was not loaded. The following error messages was displayed: [Config flow could not be loaded: {“message”:”Invalid handler specified”}]
I have deleted my device, deleted the HACS integration, restarted HA, reloaded 2.04 via HACS and when I try and add a new Pod Point device I get the same error message.
After having removed 2.04 from HACS, restarting I tried to download a previous version (2.0.3) but despite doing that it reloaded 2.0.4.
Any suggestions as to where I can get a previous version from Git Hub so I can retry with 2.0.3?
I’m on a fairly old version of HA - Home Assistant 2023.8.1
Frontend 20230802.0 - latest
I’m reluctant to upgrade in case I break my Mazda Integration.
