Any luck with connecting these to HA / detecting motion sparky? We’re moving in to our newly bought house in Syd soon and are looking for a suitable solution.
I have hooked one up but cant seem to get the ffmpeg component to work which I think is because I’m using Hass.IO rather than Hassbian. I’ve read some other people having problems with that component in Hass.IO too. Although I am very new to Home Assistant so it might just be me! I’ll be putting in some more time trying to work through all the issues I have with my install next week as it isn’t just the ffmpeg that’s giving me problems, I have a bunch of other things not working quite right as well.
I would advise against using this component, at least if the camera is using rstp stream, performance are simply too poor. With camera exposing an mpeg/m-jpeg stream it should work fine.
ok thanks, so is there something better that uses the rstp stream? or are you just suggesting that in general Hass.IO will struggle too much with a video feed?
I have actually now received info from the manufacturer of the cameras as to how I can access still images which is really all I want Hass.IO to do, so they can be sent in notifications. As for motion detection and recording etc, i plan to leave that to a dedicated server.
Only with rstp video feed, with an mpeg of m-jpeg feed I thing the performance are pretty good.
I run an HA on a home server, much more powerful than a raspberry, but it was still not enough to convert the rstp stream using ffmpeg.
If the camera can provide a jpeg image feed it sure won’t be an issue. Which video feed does the camera offer?
i know it has rstp but I haven’t looked into what else it have offer. I guess it might be worth an email to my contact at the manufacturer… she is really helpful.
where to buy them?
YOu can install them on a vertical wall outdoor?
I buy them direct from the manufacturer in China. Website is www.ccdcam.cn Yes, you can mount them on a vertical wall outdoors, I had three mounted that way in my last house for years without any issue. The model I prefer is: http://www.ccdcam.cn/product/H265_IMX326_5MP_Security_CCTV_DWDR_Vandalproof_Network_POE_Camera_with_two_way_Audio.html
This company also sells network video recorders, PoE ethernet switches, cables etc, (everything you need for a full recording setup) very cheap.
thanks.
Support for Tinycam?
Here you go, These are great cameras.
Does this camera integrate well with HA? (Notably the live stream?)
It does your answer should be in here somewhere,
https://community.home-assistant.io/search?q=dah
I run a Blue Iris server and have had that integrated into Hass in the past. BTW, If you decide to order one of these Andy is a great guy to deal with. I’ve ordered 6 or so cameras from him and always have them in 3-4 days from China.
Can you have a sensor in HASS triggered by camera motion event?
+1. I have four of these and love them. I’ve posted about a python script I use to monitor for IVS smart detection events that I’ve connected to HomeAssistant via MQTT. Great setup.
Yes, I have them turning outside lights when cameras detect motion.
Super cool, can you share the code.
What’s the price of the camera, I Queried, but no answer
Would your code work with Hikvision camera? I have 2 but don’t know how to have the motion trigger as sensor
I don’t know, but I just posted a separate topic: Dahua IP cam IVS event as binary_sensor equals smarter camera motion detection
Here’s mine, also have a script in it to check if the switch is manually on.
- alias: Turn on south/sw lights when there is movement
platform: state
entity_id:
- binary_sensor.blue_iris_frontclone
- binary_sensor.blue_iris_eastclone
- binary_sensor.blue_iris_garageclone
- binary_sensor.blue_iris_fdclone
to: 'on'
condition:
- condition: state
entity_id: sun.sun
state: 'below_horizon'
# - service: switch.turn_on
# entity_id:
# - switch.front_door_switch
# - switch.south_west_switch
- service: script.turn_on
entity_id:
- script.front_light_auto_on
- script.southwest_light_auto_on
- alias: Turn off south/sw lights 8 seconds after last movement
platform: state
entity_id:
to: 'off'
for:
seconds: 8
# - service: switch.turn_off
# entity_id:
entity_id:
- script.front_light_auto_off
- script.southwest_light_auto_off
I am new to this. How you get the blue iris sensor?
