I wouldn’t be so sure about the numbers on this list. Despite what @francisp said, I have not one device that is not working. A few of them took a little longer to crack, but in the end all is working.
What I want to say is this: this list would tend to be filled with devices, that aren’t working because of user errors, wrong buying (someone bought Zigbee but wanted Z-Wave), differences with the seller and so on… How would you check the list, and filter out all these entries…?
The best way for people to check, is to do two small searches: one on Startpage/Google/Bing and one here in the forum. If something is wrong with the device, it will popup very fast.
That’s totally true, my first go to is to look in the forum, and if I can’t find any notice of the device, I’ll look for something different. Isn’t it fun to be a HomeAutomationEnthusiast?!?
There are so many points of failure and to think that a really cheap device may now be listed on some blacklist because of some noob getting it wrong… well you can see where I am going…
It would almost be better to simply trawl the forums before buying and validating that a device wil lwork…
I have (albeit some years ago), suggested that there is an area on home-assistant.io which almost is like a “Shop” whereby nabu casa could earn affiliate revenues for directing punters to certain products that we all agree are sound products…
I prefer this “positive” approach to a “negative” approach where we just go about slagging off products on some blacklist…
I think it would be useful to have a source - which can be community project out of experiences - with devices that work so why nu turn it around: who plays nice with HA!
There could be categories like what works out of the box, need some fiddling (firmware, …)
There is a custom component for Tapo sockets and bulbs. Just do a bit of search.
They can be controlled locally once you set them up first with the Tapo app.
Just read along the topic, you will see. And actually someone made a Bluetooth solution to set up the plug without a Tapo account.
Yes, before purchasing anything else I would seriously stop and think about your plans… especially as far as bulbs/switches go… decide if WiFi Zigbee or Zwave is the route you wanna go. Consider your router and it’s capability to handle 40-50 WiFi devices as most “basic” consumer routers start to struggle with dropped connections over about 30 devices (even though their specs/literature may say otherwise)… then pick a protocol and build on it… you will obviously end up with a mixed system as that is whole point of Home Assistant… but use this as a guide to your purchases… Integrations - Home Assistant and see if the device you plan to buy is listed as being supported. Is future support guaranteed? Absolutely not… but it will make your whole journey a little more bearable…
Which Tapo devices? There are a lot, and I mean really a lot. And generally, you need to register them first into the Tapo system to make them work locally. But most of them is supported by the built in Tapo (TP-Link) integration, and all the control is local (you can block the internet for the devices).
The switch in question is the Tapo S515 Matter Smart Wi-Fi Light Switch.
Yes I was able to add it to Home Assistant via the Matter integration HOWEVER Home Assistant asked for the TP-Link Cloud user name and password before it was add the S515.
What method did you use to block the device from the Internet?
I understand that you could block the devices IPv4 address from sending or receiving Internet traffic BUT if Home Assistant has my TP-Link Cloud Account login credentials then isn’t Home Assistant communicating with TP-Link Cloud? Maybe periodically to verify / keep active / registered the device??? Maybe Home Assistant is as a relay between TP-Link Cloud and the device???
I guess, you do understand how old is this topic. (4 year) At that time Matter was still called CHIP.
So, I have no idea about that actual model, that is quite new.
I guess you have set it up by the TP-Link integrartion and not the Matter one, because that would include QR code reading or something similar.
Do you understand the privacy focus of Home Assistant? It is not relaying anything. The username and password is required, because you need those to communicate with the switch, as when you set it up in the Tapo app, that supplied those to your device to communicate with the Tapo servers, and you could access it locally as well with the same credentials.
