This blueprint aims to simplify scheduling a simple pool setup with a pump (filter). You set the pool size (volume) and the pump’s flow rate and the automation takes care of controlling the pump for the optimal circulation turnovers. You can limit the hours of day the pump should work as well.
All you need is your pool setup specs and a switch to control the pump.
blueprint:
name: Pool Pump Scheduler
description: Schedules pool pump based on its capacity and pool size. Just set your pools ize (volume), your pump flow rate and desired time limit the pump can rum daily. The automation will calculate the turnover rate and swithes on and off the pump as required.
domain: automation
input:
pool_pump:
description: A switch that controls the pool pump
selector:
entity:
domain: switch
pool_volume:
description: The capacity of the pool. This will be used to calculate the turnover rate of your pool. Use the same bas unit for Pool Volume and Pump Flow Rate!
selector:
number:
min: 1
max: 300
unit_of_measurement: "gal/m3/l"
mode: box
pump_flow_rate:
name: Pump Flow Rate
description: The flow rat eof your pool pump. This will be used to calculate the turnover rate fo your pool. Use the same bas unit for Pool Volume and Pump Flow Rate!
selector:
number:
min: .5
max: 300
unit_of_measurement: "gph/m3ph/lph"
step: .5
mode: box
maximum_run_time:
name: Maximum Pump Run Time Per Day
description: The deisred pump run time per day.
selector:
number:
min: 0
max: 24
mode: slider
unit_of_measurement: hours
default: 8
season_toggle:
name: Pool Season toggle
description: Adds ability to completely turn on-off the automation using a switch or boolean helper
selector:
entity:
domain:
- input_boolean
- switch
variables:
var_pool_pump: !input pool_pump
var_pool_volume: !input pool_volume
var_pump_flow_rate: !input pump_flow_rate
var_maximum_run_time: !input maximum_run_time
var_turnover_rate: '{{ (var_pool_volume | float(1)) / (var_pump_flow_rate | float(1)) }}'
var_turnover_per_day: '{{ 24 / var_turnover_rate }}'
var_runs_per_day: '{{ ((var_maximum_run_time | int(1)) / var_turnover_rate) | round(0) }}'
var_pump_state_changed_sice: '{{ (now().timestamp() - as_timestamp(states[var_pool_pump].last_changed)) / 3600 }}'
var_max_off_time: '{{ (24 - var_maximum_run_time | int) / var_runs_per_day }}'
- platform: time_pattern
minutes: /1
# proper trigger after variables in trigger will be supported
# - platform: template
# id: on_trigger
# value_template: >-
# {% if is_state(var_pool_pump, 'on') and (var_pump_state_changed_sice > var_turnover_rate) %}true{% endif %}
# id: off_trigger
# {% if is_state(var_pool_pump, 'off') and (var_pump_state_changed_sice > var_max_off_time) %}true{% endif %}
condition: []
- choose:
- conditions:
- condition: state
entity_id: !input pool_pump
state: 'off'
- condition: state
entity_id: !input season_toggle
state: 'on'
- condition: template
value_template: >-
{{ var_pump_state_changed_sice > var_max_off_time }}
# - condition: trigger
# id: on_pattern
sequence:
- service: switch.turn_on
- conditions:
# id: off_pattern
- condition: state
state: 'off'
- condition: state
state: 'on'
value_template: >-
{{ var_pump_state_changed_sice > var_turnover_rate }}
sequence:
- service: switch.turn_off
- conditions:
- condition: state
state: 'off'
sequence:
default: []
mode: single
