Hello.
I recently implemented an external cifs storage for my backups.
after i reboot, for example after updating custom integrations from hacs, i have to manually remount the drive
it is easy, just click on the notification , press the button.
but it would be really good, if we had a service, that we could call with an automation, with fail and success , to retry.
this would be handy after a power outage etc. because I cant always react in time, whe things hit the fan
This might not be perfect but you might be able to use it as a workaround.
The Need
Smart homes include a network of devices. A case of a failed command can happen due to temporary connectivity issues or invalid device states. The cost of such a failure can be high, especially for background automation. For example, failing to shutdown a watering system which should run for 20 minutes can have severe consequences.
Any machine or device can break down, so it’s not possible to have full guarantee without redundancy (which is most likely less relevant for smart homes). …
Can’t you also use a command line sensor instrution to mount the drive if you had to?
I don’t know, how it works in the background, it is shown as supervisor repair option.
if i knew how it worked in the background, then an automatic reload via command line COULD be possible
Just do some reseach on how to mount a drive from the command line in linux, the code is pretty simple (mount and umount)
I know how to mount in Linux, but wouldn’t it collide with the supervisor in this case? would the warning still be there?
36rpg
April 15, 2024, 4:19pm
6
@Maschinenherz I have the same issue that you describe.
Did you find an alternative ?
Is there an API call we can use in a shell_command maybe ?
Thanks !
36rpg
April 15, 2024, 10:25pm
7
Hi again,
I followed the shell_command lead using the following command:
> remount_nas: |-
> list_uuids() {
> curl -sSL -H "Authorization: Bearer $SUPERVISOR_TOKEN" http://supervisor/resolution/info | jq -r '.data.suggestions[] | select(.type == "execute_reload").uuid';
> uuids=$(list_uuids)
> for uuid in ${uuids}
> do
> curl -sSL -X POST -H "Authorization: Bearer $SUPERVISOR_TOKEN" http://supervisor/resolution/suggestion/${uuid};
> done
Seems to work ok but the repair notifications are not cleared immediately in the UI.
If any one has a better way of clearing the repair alarm when NAS comes back up, I’ll be delighted to hear it.
Thanks all.
