I noticed an alarming increase in memory usage and also a high CPU-load. I’m running Supervisor 229, Home-Assistant 0.113.3 and no custom integrations (actually HACS is still installed but I already removed all custom integrations installed from HACS). Home-Assistant runs on an Intel NUC (intel i7 CPU) and “eats” about 40% of the available CPU power. Memory usage is about 500MB but increasing steadily. See these graphs from the last 7 days.
It did help for a few hours. Up to about 8pm the CPU load was way lower than it was ever before. But at almost exactly 8pm it went through the roof.
Memory is also still increasing, but only slightly. This graph shows the last 24 hours.
At the same time the received network traffic went up too. So I wonder if it’s an external source. I’ll have to dig deeper.
IMHO removing Tradfrii did help for the first few hours so it was one step. But others are possibly needed too.
Somehow I missed the thread about CPU-Usage in 0.113. Thanks for linking it. Just to make sure it is not related, I’ve now also removed HomeKit Bridge. Currently Home-Assistant uses about 25% of the i7 CPU – still a lot. But much less than before.
I’ll wait another day to see how it changes over the next hours.
Just to make sure I removed HomeKit Bridge and moved back to 0.112.4. This is the result over 12h (I switched to 0.112.4 where the dip in the memory consumption is)
I also did run py-spy on 0.114.0 where the CPU usage was over 50%. I let it run for about 10 minutes, this is the resulting file. Sonos and mDNS seem to be involved but I can’t really interpret the results.
Any more ideas? I start to think about building a completely new environment but I do have hundreds of entities and many dozens of automations. So this is a big project .
