Postgresql to SQLite migration, moving back to SQLite
I’ve been running my Home Assistant database on PostgreSQL for a while due to issues with the Recorder’s SQLite database. However, since the Recorder has seen improvements (like long-term statistics), I decided to migrate back to SQLite. Additionally, my PostgreSQL ran on a separate server which added complexity, and I’d like the option to turn off that server occasionally without impacting my Home Assistant setup.
I couldn’t find a straightforward guide on how to migrate data back to SQLite, so I decided to try my luck and figure it out myself. I’m sharing my process here to help others who might be in a similar situation. This is a rough guide, but it should provide a good starting point!
Steps I Followed:
  1. Clean up data in PostgreSQL:
    • Reduce the amount of data to migrate. Less data means a faster migration.
    • This step is the only one that actually deletes anything. So make backups as needed.
  2. Export data from PostgreSQL to CSV:
    • Ensure the column order matches the SQLite schema and apply necessary transformations (like datetime and boolean conversions) during export.
  3. Prepare a fresh home-assistant_v2.db database:
    • Start with a clean slate for importing the data.
  4. Import the CSV files into SQLite:
    • Use the SQLite command-line tool to import each CSV file into the corresponding table.
  5. Fix null fields:
    • CSV files don’t natively handle null values, so empty strings need to be replaced with nulls.
  6. Finish up and enjoy:
    • Verify everything is working correctly with your newly migrated SQLite database.
Detailed Process
My PostgreSQL database was quite large—around 80 GB. I had set my Recorder retention to 365 days, which retained a lot of data. To reduce this, I started by cleaning up the states table, setting the Recorder to purge data older than 10 days. Despite several days of waiting (and invocations of the purge service), I still had hundreds of millions of rows, so I needed another approach.
Eventually, I decided to rename my states table to states_old and create a new states table with the same structure. Here’s why:
  • Figure out what to delete: Depending on your data needs, decide how much you can safely delete.
  • Renaming the table: Since I needed to keep about 12% of my data, it was faster to insert the needed rows into a new table than to delete rows from the old one.
  • Protip, adjusting sequence numbers: If, like me, you get sidetracked and need to run on the Postgres again for a while. Make sure to set the sequence number for new rows higher than your current max state_id. This ensures Home Assistant continues functioning without conflicts. Search the internet for how to do this.
My Script
Below is the script I used. It’s more of a series of notes than a script you can run directly. You can copy-paste these commands to handle the export from PostgreSQL to CSV, making sure to apply the necessary data transformations. Note that the column layout should match your SQLite database.
After exporting, get a fresh home-assistant_v2.db from Home Assistant. I did this by reconfiguring my Recorder to use the built-in database, restarting Home Assistant, and waiting for it to create a new database file. Then, I stopped Home Assistant again to perform the import.
Export Data from PostgreSQL
Adjust credentials and other details as necessary
# Set PostgreSQL credentials and server details
PGHOST="postgres.home"
PGDATABASE="homeassistant"
PGUSER="homeassistant"
PGPASSWORD="homeassistant"
# Export data to CSV files with column ordering, date formatting, and boolean conversion
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT data_id, hash, shared_data FROM event_data) TO 'event_data.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT event_type_id, event_type FROM event_types) TO 'event_types.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT attributes_id, hash, shared_attrs FROM state_attributes) TO 'state_attributes.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT metadata_id, entity_id FROM states_meta) TO 'states_meta.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, statistic_id, source, unit_of_measurement, CASE WHEN has_mean THEN 1 ELSE 0 END as has_mean, CASE WHEN has_sum THEN 1 ELSE 0 END as has_sum, name FROM statistics_meta) TO 'statistics_meta.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT run_id, (start AT TIME ZONE 'UTC')::timestamp as start, (\"end\" AT TIME ZONE 'UTC')::timestamp as \"end\", CASE WHEN closed_incorrect THEN 1 ELSE 0 END as closed_incorrect, (created AT TIME ZONE 'UTC')::timestamp as created FROM recorder_runs) TO 'recorder_runs.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT migration_id, version FROM migration_changes) TO 'migration_changes.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT change_id, schema_version, (changed AT TIME ZONE 'UTC')::timestamp as changed FROM schema_changes) TO 'schema_changes.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT run_id, (start AT TIME ZONE 'UTC')::timestamp as start FROM statistics_runs) TO 'statistics_runs.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, (created AT TIME ZONE 'UTC')::timestamp as created, created_ts, metadata_id, (start AT TIME ZONE 'UTC')::timestamp as start, start_ts, mean, min, max, (last_reset AT TIME ZONE 'UTC')::timestamp as last_reset, last_reset_ts, state, sum FROM statistics) TO 'statistics.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, (created AT TIME ZONE 'UTC')::timestamp as created, created_ts, metadata_id, (start AT TIME ZONE 'UTC')::timestamp as start, start_ts, mean, min, max, (last_reset AT TIME ZONE 'UTC')::timestamp as last_reset, last_reset_ts, state, sum FROM statistics_short_term) TO 'statistics_short_term.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT event_id, event_type, event_data, origin, origin_idx, (time_fired AT TIME ZONE 'UTC')::timestamp as time_fired, time_fired_ts, context_id, context_user_id, context_parent_id, data_id, context_id_bin, context_user_id_bin, context_parent_id_bin, event_type_id FROM events) TO 'events.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT state_id, entity_id, state, attributes, event_id, (last_changed AT TIME ZONE 'UTC')::timestamp as last_changed, last_changed_ts, last_reported_ts, (last_updated AT TIME ZONE 'UTC')::timestamp as last_updated, last_updated_ts, old_state_id, attributes_id, context_id, context_user_id, context_parent_id, origin_idx, context_id_bin, context_user_id_bin, context_parent_id_bin, metadata_id FROM states) TO 'states.csv' CSV HEADER"
Prepare and Import into SQLite
  1. Acquire the home-assistant_v2.db: Get a fresh database file by reconfiguring Home Assistant to use SQLite, restarting it, and then stopping it once the new database is created.
  2. Open the SQLite database using the SQLite CLI tool:
    sqlite3 home-assistant_v2.db
  3. Clean out existing data that Home Assistant may have saved before shutting down:
    DELETE FROM main.event_data;
    DELETE FROM main.event_types;
    DELETE FROM main.events;
    DELETE FROM main.statistics_meta;
    DELETE FROM main.statistics_runs;
    DELETE FROM main.statistics;
    DELETE FROM main.states;
    DELETE FROM main.states_meta;
    DELETE FROM main.statistics_short_term;
    DELETE FROM main.state_attributes;
    DELETE FROM main.recorder_runs;
    DELETE FROM main.migration_changes;
  4. Import data from the CSV files exported from PostgreSQL:
    .mode csv
    .import event_data.csv event_data
    .import event_types.csv event_types
    .import state_attributes.csv state_attributes
    .import states_meta.csv states_meta
    .import statistics_meta.csv statistics_meta
    .import recorder_runs.csv recorder_runs
    .import migration_changes.csv migration_changes
    .import statistics_runs.csv statistics_runs
    .import statistics_short_term.csv statistics_short_term
    .import statistics.csv statistics
    .import events.csv events
    .import states.csv states
  5. Replace empty strings with NULL for all nullable fields:
   ## Replace empty strings with NULL in 'event_data'
   UPDATE event_data SET
    hash = NULLIF(hash, ''),
    shared_data = NULLIF(shared_data, '');
   ## Replace empty strings with NULL in 'event_types'
   UPDATE event_types SET
    event_type = NULLIF(event_type, '');
   ## Replace empty strings with NULL in 'state_attributes'
   UPDATE state_attributes SET
    shared_attrs = NULLIF(shared_attrs, '');
   ## Replace empty strings with NULL in 'states_meta'
   UPDATE states_meta SET
    entity_id = NULLIF(entity_id, '');
   ## Replace empty strings with NULL in 'statistics_meta'
   UPDATE statistics_meta SET
    statistic_id = NULLIF(statistic_id, ''),
    source = NULLIF(source, ''),
    unit_of_measurement = NULLIF(unit_of_measurement, ''),
    name = NULLIF(name, '');
   ## Replace empty strings with NULL in 'recorder_runs'
   UPDATE recorder_runs SET
    start = NULLIF(start, ''),
    end = NULLIF(end, '');
   ## Replace empty strings with NULL in 'migration_changes'
   ## No nullable fields
   ## Replace empty strings with NULL in 'schema_changes'
   UPDATE schema_changes SET
    schema_version = NULLIF(schema_version, '');
   ## Replace empty strings with NULL in 'statistics_runs'
   ## Replace empty strings with NULL in 'events'
   UPDATE events SET
    event_type = NULLIF(event_type, ''),
    event_data = NULLIF(event_data, ''),
    origin = NULLIF(origin, ''),
    context_id = NULLIF(context_id, ''),
    context_user_id = NULLIF(context_user_id, ''),
    context_parent_id = NULLIF(context_parent_id, ''),
    context_id_bin = NULLIF(context_id_bin, ''),
    context_user_id_bin = NULLIF(context_user_id_bin, ''),
    context_parent_id_bin = NULLIF(context_parent_id_bin, '');
   ## Replace empty strings with NULL in 'statistics'
   UPDATE statistics SET
    created = NULLIF(created, ''),
    mean = NULLIF(mean, ''),
    min = NULLIF(min, ''),
    max = NULLIF(max, ''),
    last_reset = NULLIF(last_reset, ''),
    state = NULLIF(state, ''),
    sum = NULLIF(sum, '');
   ## Replace empty strings with NULL in 'statistics_short_term'
   UPDATE statistics_short_term SET
   ## Replace empty strings with NULL in 'states'
   UPDATE states SET
    entity_id = NULLIF(entity_id, ''),
    attributes = NULLIF(attributes, ''),
    last_changed = NULLIF(last_changed, ''),
    last_updated = NULLIF(last_updated, ''),
Conclusion
By following these steps, you should be able to successfully migrate your Home Assistant database from PostgreSQL back to SQLite. The process involves careful handling of data types and null values, but it’s definitely doable. Good luck!
Related Posts:
Hi Michael Bisbjerg,
This looks great. Added it to the cookbook for you so we can easy reference it. I look in the Cookbook first for links when helping others.
Also the Maria post is listed in the Cookbook that is the Community Guide Compilation of the other thread you referenced.
This migration worked great for me. Thank you for sharing. Just a few tips for others that run through it.
  1. I had to remove the headers on each CSV to do the import.
  2. If you are getting read only errors on the sqllite DB, make sure you are opening it as the correct user permissions from the OS side. I use a container so I had to run the import and commands with privilege.
  3. Run one command at a time so you can assure its working as expected.
Migration successful. No more Postgres DB. Thanks!
Thanks for this guide! I put together a shell script that combines all the above snippets, plus the following changes:
  • Included schema_changes in the import
  • Added a few more nullable fields, specifically ones ending in _ts
  • Adjusted the psql dump commands so they work for containerized postgres
#!/bin/sh
# Create a temporary folder for the CSV files
mkdir -p ha_tmp
PSQL_CMD="psql" # See below for containerized examples
# PSQL_CMD="docker exec -it postgres-container psql"
# PSQL_CMD="podman exec -it postgres-container psql"
# Export data to CSVs
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT data_id, hash, shared_data FROM event_data) TO STDOUT CSV" > ha_tmp/event_data.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT event_type_id, event_type FROM event_types) TO STDOUT CSV" > ha_tmp/event_types.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT attributes_id, hash, shared_attrs FROM state_attributes) TO STDOUT CSV" > ha_tmp/state_attributes.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT metadata_id, entity_id FROM states_meta) TO STDOUT CSV" > ha_tmp/states_meta.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, statistic_id, source, unit_of_measurement, CASE WHEN has_mean THEN 1 ELSE 0 END as has_mean, CASE WHEN has_sum THEN 1 ELSE 0 END as has_sum, name FROM statistics_meta) TO STDOUT CSV" > ha_tmp/statistics_meta.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT run_id, (start AT TIME ZONE 'UTC')::timestamp as start, (\"end\" AT TIME ZONE 'UTC')::timestamp as \"end\", CASE WHEN closed_incorrect THEN 1 ELSE 0 END as closed_incorrect, (created AT TIME ZONE 'UTC')::timestamp as created FROM recorder_runs) TO STDOUT CSV" > ha_tmp/recorder_runs.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT migration_id, version FROM migration_changes) TO STDOUT CSV" > ha_tmp/migration_changes.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT change_id, schema_version, (changed AT TIME ZONE 'UTC')::timestamp as changed FROM schema_changes) TO STDOUT CSV" > ha_tmp/schema_changes.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT run_id, (start AT TIME ZONE 'UTC')::timestamp as start FROM statistics_runs) TO STDOUT CSV" > ha_tmp/statistics_runs.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, (created AT TIME ZONE 'UTC')::timestamp as created, created_ts, metadata_id, (start AT TIME ZONE 'UTC')::timestamp as start, start_ts, mean, min, max, (last_reset AT TIME ZONE 'UTC')::timestamp as last_reset, last_reset_ts, state, sum FROM statistics) TO STDOUT CSV" > ha_tmp/statistics.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, (created AT TIME ZONE 'UTC')::timestamp as created, created_ts, metadata_id, (start AT TIME ZONE 'UTC')::timestamp as start, start_ts, mean, min, max, (last_reset AT TIME ZONE 'UTC')::timestamp as last_reset, last_reset_ts, state, sum FROM statistics_short_term) TO STDOUT CSV" > ha_tmp/statistics_short_term.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT event_id, event_type, event_data, origin, origin_idx, (time_fired AT TIME ZONE 'UTC')::timestamp as time_fired, time_fired_ts, context_id, context_user_id, context_parent_id, data_id, context_id_bin, context_user_id_bin, context_parent_id_bin, event_type_id FROM events) TO STDOUT CSV" > ha_tmp/events.csv
$PSQL_CMD -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT state_id, entity_id, state, attributes, event_id, (last_changed AT TIME ZONE 'UTC')::timestamp as last_changed, last_changed_ts, last_reported_ts, (last_updated AT TIME ZONE 'UTC')::timestamp as last_updated, last_updated_ts, old_state_id, attributes_id, context_id, context_user_id, context_parent_id, origin_idx, context_id_bin, context_user_id_bin, context_parent_id_bin, metadata_id FROM states) TO STDOUT CSV" > ha_tmp/states.csv
# Back up our template sqlite database in case of problems
cp home-assistant_v2.db home-assistant_v2.db.orig
sqlite3 home-assistant_v2.db <<'END_SQL'
# Clear out any existing data
DELETE FROM main.schema_changes;
# Import CSVs
.mode csv
.import ha_tmp/event_data.csv event_data
.import ha_tmp/event_types.csv event_types
.import ha_tmp/state_attributes.csv state_attributes
.import ha_tmp/states_meta.csv states_meta
.import ha_tmp/statistics_meta.csv statistics_meta
.import ha_tmp/recorder_runs.csv recorder_runs
.import ha_tmp/migration_changes.csv migration_changes
.import ha_tmp/schema_changes.csv schema_changes
.import ha_tmp/statistics_runs.csv statistics_runs
.import ha_tmp/statistics_short_term.csv statistics_short_term
.import ha_tmp/statistics.csv statistics
.import ha_tmp/events.csv events
.import ha_tmp/states.csv states
UPDATE events SET
 last_reset_ts = NULLIF(last_reset_ts, ''),
UPDATE states SET
 last_changed_ts = NULLIF(last_changed_ts, ''),
 last_reported_ts = NULLIF(last_reported_ts, ''),
END_SQL
Great!.. Glad it helped.
I didn’t note the headers on each file, as sqlite ignored them for me. It’s evident if you run the same import twice, where it only complains on the headers line in the first, but on the second run it complains about the headers and that all rows are duplicate.
I opted specifically not to include the schema changes table. I was unsure if the schema migrations were different between postgres and sqlite, so I opted to let HA create the sqlite database, and then I removed all data except the schema migrations.
Then when importing, leave the schema as is.
This ensures that we don’t suddenly see HA make a migration on data it shouldn’t.
I looked through the code base and as far as I can tell only the last schema_changes entry is ever used, so it should be safe. I guess I’ll find out the next time the schema gets updated :stuck_out_tongue:
Does anyone have an updated script that supports the current Homeassistant version? Seem like the schema changed slightly. Otherwise I’ll try to have a look.
Edit: I ended up not using a CSV export, but an SQL dump. With CSV you have to manually convert the NULL values and it doesn’t support importing the BLOB columns in events and states, which means that the history of states is then broken.
What seemed to have worked is:
#!/bin/bash
set -eux
PGHOST="..."
PGPASSWORD="..."
export PGPASSWORD
pg_dump --data-only --inserts homeassistant > dump.sql
# Fix boolean representation
sed -i 's/true/"t"/g' dump.sql
sed -i 's/false/"f"/g' dump.sql
# Remove 'public' prefix from table names
sed -i "s/public.//g" dump.sql
# Convert BLOB format
sed -i "s/'\\\\x/x'/g" dump.sql
# Remove unsupported & unnecessary commands
sed -i 's/SET/-- SET/g' dump.sql
sed -i 's/SELECT pg_catalog/-- SELECT pg_catalog/g' dump.sql
# Skip schema_changes table
sed -i '/schema_changes/d' dump.sql
# Wrap in BEGIN/END to speed up process by using a single transaction.
sed -i '1s/^/BEGIN;\n/; $s/$/\nEND;/' dump.sql
END_SQL
sqlite3 home-assistant_v2.db < dump.sql
Note that I skipped the schema_chages table as suggested.
At least homeassistant started fine without recorder errors. And history graphs as well as state statistics worked fine.
@LordMike thanks the migration worked for me with 2 minor things:
probably the schema got adjusted in the meantime, I had to adjust the psql export slightly, for example to add the mean_weight column to statistics. Without that the sqlite import would give quite some column count mismatch errors.
Removing the first row of the csv should also be done, the datatype mismatch will usually ignore this line but not for every table.
Here’s the script which worked for me:
export PGHOST="..."
export PGDATABASE="..."
export PGUSER="..."
export PGPASSWORD="..."
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, statistic_id, source, unit_of_measurement, CASE WHEN has_mean THEN 1 ELSE 0 END as has_mean, CASE WHEN has_sum THEN 1 ELSE 0 END as has_sum, name, mean_type FROM statistics_meta) TO 'statistics_meta.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, (created AT TIME ZONE 'UTC')::timestamp as created, created_ts, metadata_id, (start AT TIME ZONE 'UTC')::timestamp as start, start_ts, mean, mean_weight, min, max, (last_reset AT TIME ZONE 'UTC')::timestamp as last_reset, last_reset_ts, state, sum FROM statistics) TO 'statistics.csv' CSV HEADER"
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, (created AT TIME ZONE 'UTC')::timestamp as created, created_ts, metadata_id, (start AT TIME ZONE 'UTC')::timestamp as start, start_ts, mean, mean_weight, min, max, (last_reset AT TIME ZONE 'UTC')::timestamp as last_reset, last_reset_ts, state, sum FROM statistics_short_term) TO 'statistics_short_term.csv' CSV HEADER"
# Remove header of csv files
for file in *.csv; do
 if [ -f "$file" ]; then
 tail -n +2 "$file" > temp.csv && mv temp.csv "$file"
 fi
done
sqlite3 "home-assistant_v2.db" <<'END_SQL'
.mode csv
UPDATE events SET
 mean_weight = NULLIF(mean_weight, ''),
UPDATE states SET
END_SQL
Thanks for this! I just used this for my own migration. The only thing I had to change (I assume as well because of a meta change) was to add the column ‘unit_class’ for statistics_meta:
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, statistic_id, source, unit_of_measurement, unit_class, CASE WHEN has_mean THEN 1 ELSE 0 END AS has_mean, CASE WHEN has_sum THEN 1 ELSE 0 END AS has_sum, name, mean_type FROM statistics_meta) TO 'statistics_meta.csv' CSV HEADER"
Had some help from an LLM since I’m always struggling with sql, but it appears to have worked (without it it would complain about a column mismatch).
I would be interested to know what motivates someone to move to PostgreSQL in the first place. And then what motivates them to move back.
For me I had some issues with sqlite. I wanted to store a lot of data in the recorder, because who doesn’t like stats, which dragged its feet in sqlite. As I was already running a Postgres on the same server, I moved my data there. It did work wonders. I could store a lot of stats, and HA didn’t lag.
A few years later, I’ve had a bunch of issues with the postgres, because I’m not a DBA and I was using the Postgres for other stuff too. So it faltered (disk space usage, load from other apps, …) and then I even moved my HA instance off the machine (to raise stability, as I rebooted my server more often than I wanted my HA to go down)… which then prompted that HA relied on a Postgres on another box which just doubled all issues.
Finally, HA introduced long term stats, which is a way smarter way to do stats - as we really don’t need granularity at the level of every-state-update-forever… All this together meant: I’ll just reduce recorder activity to days (7… 14… whatever), and move all data back to sqlite.
Now HA is contained on its own box, it relies only on sqlite, and it manages it by itself. Stability++.
So in the end, my reason for moving lies in the environment changing. My HA install is 6-7 years old by now, so it’s seen a lot of changes. For example, I’m now on an ODroid M1, solely for HA, which means I run HAOS on it and have opted not to managed packages on it (which I’d usually do).
I would like to say thank you so much to everyone in this thread. I have been able to get back to SQLite following a mix of the instructions provided (latest db version, containerized postgres) and now I can move forward to entirely drop the postgres DB.
In my case, years ago, apart from the “postgres is a more efficient db compared to sqlite”, I was part of the bandwagon that tried (and failed!) to configure Graphana.
I made some attempts to get back to sqlite, but this thread is pure gold.
2026 Update: Schema Shifts and the 3-Table Fast Track
Massive thanks to LordMike for the brilliant \COPY (SELECT...) methodology—handling the boolean conversions before they hit CSV is absolutely the way to go. I just completed this migration in August 2026 and wanted to contribute a few critical updates regarding Home Assistant’s evolving database schema.
If you attempt this on a modern HA build using the older queries, SQLite’s blind .import will trigger NOT NULL constraint failures because the column orders have shifted.
Here are some notes on what I did. Unfortunately I don’t have time to re-write the whole procedure in the OP, but here is where I deviated.
1. The 2026 Schema Requirements
  • statistics_meta now requires 9 columns. unit_class is inserted at index 4, shifting the booleans and pushing mean_type to index 8.
  • statistics and statistics_short_term now require 14 columns, with mean_weight inserted at index 7.
Here are the updated PostgreSQL export commands to match the modern SQLite schema:
Bash
psql -h $PGHOST -U $PGUSER -d $PGDATABASE -c "\COPY (SELECT id, statistic_id, source, unit_of_measurement, unit_class, CASE WHEN has_mean THEN 1 ELSE 0 END as has_mean, CASE WHEN has_sum THEN 1 ELSE 0 END as has_sum, name, mean_type FROM statistics_meta) TO 'statistics_meta.csv' CSV HEADER"
2. The Header-Strip Workaround Depending on your HA container build, the SQLite interactive shell might reject the --skip 1 flag during .import. To avoid importing the CSV headers as data rows, strip them directly in bash before launching sqlite3:
Bash
tail -n +2 /backup/statistics_meta.csv > /backup/meta_clean.csv
tail -n +2 /backup/statistics.csv > /backup/stats_clean.csv
tail -n +2 /backup/statistics_short_term.csv > /backup/short_clean.csv
3. Updated NULLIF Cleanup After you re-create the empty home-assistant_v2.db file, truncate its data, and import from the cleaned CSV files, you will need to clean up empty strings with something like this, which includes the newly mapped columns:
SQL
  unit_class = NULLIF(unit_class, ''),
4. The 3-Table Fast Track If you already run InfluxDB for time-series data and have your HA recorder set to a short purge window (e.g., 10 days), do not bother migrating the massive states and events tables. You can surgically migrate just the three tables above to preserve just your Energy Dashboard and Long-Term Statistics.
Since the forum locked my ability to edit the original post, here is the complete, final, and tested 2026 procedure—including a critical fix for the timestamp columns in Step 3 that will break your recorder if skipped. Use this version!
Massive thanks to LordMike for the \COPY (SELECT...) methodology—handling boolean conversions before they hit CSV is definitely the way to go. I just completed this migration in August 2026 and wanted to contribute a few critical updates regarding Home Assistant’s evolving database schema.
If you attempt this on a modern HA build using the older queries, SQLite’s blind .import will trigger NOT NULL constraint failures because column orders have shifted.
Here is where my procedure deviated:
Here are the updated PostgreSQL export commands matching the modern SQLite schema:
Bash
Depending on your HA container build, the SQLite interactive shell might reject the --skip 1 flag during .import. To avoid importing CSV headers as invalid data rows, strip them directly in bash before launching sqlite3:
Bash
After recreating an empty home-assistant_v2.db file, truncating its initial data, and importing the cleaned CSVs, you must clean up empty strings.
Important: Ensure you include the float timestamp columns (created_ts, start_ts, last_reset_ts). If left as empty strings ('') instead of NULL, Home Assistant’s StatisticsTask will throw a fatal TypeError: argument must be int or float, not str when compiling new metrics, halting long-term statistics generation.
SQL
  created_ts = NULLIF(created_ts, ''),
  start_ts = NULLIF(start_ts, ''),
If you already use an external TSDB (like InfluxDB or VictoriaMetrics) for granular historical metrics and keep your HA recorder on a short purge window (e.g., 10 days), you do not need to migrate the massive states and events tables. Surgically migrating only these three tables preserves your Energy Dashboard and Long-Term Statistics with minimal downtime.
