Hi there, Thank you for your work on this! I was happy to come across this for my energy dashboard. I installed the latest beta version of the PFCP and it is a really straightforward setup. I am having trouble with the card dealing with the negative value from the sensor.battery_power. It shows that as power going into the battery instead of out of it.
Am I misunderstanding how this is supposed to be setup?
Seeing some odd behaviour where entities show as bubbles but the data is inconsistent. Here is my YAML
Screenshot shows the in built energy card alongside the power flow plus card. Running 0.1b but behaviour same in 0.0.9.6. Also do not get the visual editor with the beta.
type: custom:power-flow-card-plus
entities:
fossil_fuel_percentage:
entity: sensor.co2_signal_grid_fossil_fuel_percentage
icon: mdi:leaf
color_icon: true
display_zero: true
state_type: percentage
grid:
entity:
consumption: sensor.daily_energy_total
production: sensor.export_kwh
color_circle: true
secondary_info:
unit_of_measurement: kWh
solar:
entity: sensor.powerwall_solar_export
battery:
entity:
consumption: sensor.powerwall_battery_import
production: sensor.powerwall_battery_export
state_of_charge: sensor.powerwall_charge
display_state: one_way
color_circle: true
home:
color_icon: true
color_circle: true
individual1:
entity: sensor.myenergi_eddi_21491793_energy_consumed_session
icon: mdi:heating-coil
display_zero: true
color: '#00CC44'
individual2:
entity: sensor.myenergi_eddi_21491793_none_ct3
icon: mdi:ev-station
display_zero: true
color: '#00CC44'
clickable_entities: true
display_zero_lines: true
use_new_flow_rate_model: true
min_flow_rate: 2
w_decimals: 0
kw_decimals: 1
watt_threshold: 1000
jeveli
(Jeveli)
May 2, 2023, 9:52am
45
Thanks! I have used tesla-style-solar-power-card before, but this is so much better!
jeveli
(Jeveli)
May 3, 2023, 9:20am
46
Is this possible? I want to have a few more “individual”
QuQ
(Q)
May 3, 2023, 2:04pm
47
thanks for the update fixed a few issues i was having
how are you displaying both current usage and daily within the bubbles?
heinemannj
(Joerg Heinemann)
May 4, 2023, 11:26am
51
I’m trying to misuse your exellent card …
Not using entities dealing with Power but with Energy entities:
On top power-flow-plus-card
on the buttom: custom:system-energy-flow-card
type: custom:layout-card
layout_type: custom:grid-layout
cards:
- type: vertical-stack
cards:
- type: custom:power-flow-card-plus
title: Energy Flows (Today) - power-flow-card-plus
min_flow_rate: 3
max_flow_rate: 10
kw_decimals: 3
w_decimals: 3
entities:
home: null
solar:
entity: sensor.solar_yield_daily
battery:
entity:
consumption: sensor.battery_day_discharge_with_loss
production: sensor.battery_day_charge_with_loss
state_of_charge: sensor.battery_state_of_capacity
color_circle: true
grid:
entity:
consumption: sensor.power_meter_consumption_energy_daily
production: sensor.power_meter_exported_energy_daily
icon: mdi:pine-tree
color_icon: true
display_zero: true
state_type: power
card_mod:
style:
.card-header {
line-height: 0px !important;
padding-top: 18px !important;
padding-bottom: 20px !important;
color: var(--secondary-text-color) !important;
font-size: 16px !important;
font-weight: 500 !important;
overflow: hidden !important;
white-space: nowrap !important;
text-overflow: ellipsis !important;
ha-card {
width: 360px;
height: 380px;
- type: custom:system-energy-flow-card
title: Energy Flows (Today) - system-energy-flow-card
entities:
battery:
battery_charge: sensor.battery_state_of_capacity
grid:
solar: sensor.solar_yield_daily
kwh_decimals: 3
card_mod:
style:
.card-header {
ha-card {
width: 360px;
height: 380px;
layout:
grid-template-columns: 1280px 365px
margin: 0px;
padding: 0px;
As marked in yellow the only thing which is not working out of the box is the unit of measuremen t .
Is it possible to have configuration options to define the unit, so that the change from W/kW
to Wh/kWh
can be configured individually?
tom_l
May 4, 2023, 12:48pm
52
Any reason you are not using the core energy flow card?
type: energy-distribution
title: Energy Distribution
heinemannj
(Joerg Heinemann)
May 4, 2023, 3:28pm
53
Sometimes pictures say more then 1000 of words:
cards:
- type: horizontal-stack
cards:
min_flow_rate: 3
max_flow_rate: 10
kw_decimals: 3
w_decimals: 3
entities:
home: null
solar:
battery:
entity:
color_circle: true
grid:
entity:
icon: mdi:pine-tree
color_icon: true
display_zero: true
state_type: power
card_mod:
style:
.card-header {
ha-card {
width: 360px;
height: 380px;
entities:
battery:
grid:
kwh_decimals: 3
card_mod:
style:
.card-header {
ha-card {
width: 360px;
height: 380px;
- type: energy-distribution
title: Energy Distribution - Org Card
card_mod:
style:
.card-header {
ha-card {
width: 360px;
height: 380px;
layout:
grid-template-columns: 365px 365px 365px 500px;
margin: 0px;
padding: 0px;
Same sensor’s for org HA energy dashboard as for custom cards.
All sensors are up and running since a couple of weeks.
Actually I’m improving
Huawei Solar Integration
by the usage of
and I’m quite happy with the result to setup an Energy Management System (EMS) platform …
Cheers
Joerg
I’ve made my PF+ card similar to the energy distribution card.
Using individual1 and 2 I’ve added water and gas, and inverted flow and such.
But I’d like to know how to display the value unrounded. Gallons says 8 as it’s rounded. The value is actually 7.6
s
unit_of_measurement for this device is set to ‘gal’
Is there a way to not display this as a rounded value? As w_decimal and kw_decimal have no effect.
Try using
secondary_info:
template: >-
{{ states('sensor.your_energy_sensor') | round(1) }} kWh
Then you can keep power on the bottom and energy on the top, like the screenshot in my post above?
Hi all need a bit of help
i use a shelly em2 lead 1 messures solar
lead 2 measures power with a + figure pulling from grid and - export to grid.
i use the power flow card.
with
entities:
grid: sensor.power_out_power
solar: sensor.solar_in_power
watt_threshold: 999
w_decimals: 0
the home is calculated by the card.
How do i get this card to do the same
is there a option
thanks
Newbie here.
I am trying to get this configured in my configuration.yaml using the defualt examples, but I get a configuration error from the very first line
error is:Integration error: type - Integration ‘type’ not found.
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
# Example configuration.yaml entry using cloud based Emoncms
- platform: emoncms
api_key: xxxxxxxxxxxxxxxxxxxxxxxxx
url: http://10.0.0.40/emoncms
scan_interval: 10
unit_of_measurement: "kWh"
value_template: "{{ value| round(0) }}"
include_only_feed_id:
- 18 #import-Kwh
- 20 #Solar-Kwh
- 22 #House-Use-Kwh
- 45 #SolarRebatable-Kwh
sensor_names:
18: "EmonCMS-Importing"
20: "EmonCMS-Generating"
22: "EmonCMS-Using"
45: "EmonCMS-Exporting"
- platform: emoncms
api_key: xxxxxxxxxxxxxxxxxxxxxxxxxxx
scan_interval: 10
unit_of_measurement: "kW"
- 17 #import
- 19 #Solar
- 21 #House-Use
sensor_names:
17: "EmonCMS-Import"
19: "EmonCMS-Solar"
21: "EmonCMS-House-Use"
- platform: openevse
host: 10.0.0.8
monitored_variables:
- status
- charge_time
- usage_session
- usage_total
type or paste code here
pepe59
(Pepe59)
May 9, 2023, 5:24am
58
You need to create a card in lovelace.
It doesn’t belong in configuration.yaml
Ahh!!, Thankyou.
As I said Newbie, took me a while to figure out quite what that meant, but its all good now.
Tom50
May 9, 2023, 9:27am
60
Hi all,
Since the update today - (v0.1.1) i lost the moving points between the bubbles.
Does anyone else has this problem?
pepe59
(Pepe59)
May 9, 2023, 9:38am
61
I am using version 0.1.1 and it works as expected.
Tom50
May 9, 2023, 9:58am
62
Thank you for checking.
Do you have an idea what is wrong with my code or better is there something which might cause this problem?
Up to now, everything worked.
edit: activated the new flow model and the moving points are back again.
