Hey everyone,
I’m loving Home Assistant, and have got my Zwave devices working pretty well. However I seem to be running into the following issue.
I have a couple plug-in appliance modules. They turn on/off dumb lights that are plugged into them. This works great, for a bit. However, randomly these modules will stop accepting commands from Home Assistant. If they are on, I can’t turn them off, and vice verca. The only way to get Home Assistant to control the devices is to hit the include button on the device itself. Which is a hassle as have to do this daily.
This seems to only affect powered devices. I have battery multisensors in the same areas, and they are not affected at all. Its just these plug-in modules.
Sometimes a network ‘heal’ or test will fix the issue. Sometimes not. I was hoping the “auto heal” feature that came in 0.21 would fix this, but it hasn’t.
When the devices get stuck in this state, I spin up a docker of Domoticz. In there I can see the powered devices marked as “dead”. The same goes in the OZWCP.
I’ve done some Googling, and I can see others using Domoticz have experienced the same problems. Some examples, and a recent thread.
I’m sure this is an OZWCP issue, and not a HA issue. Just wondering if anyone else here has experienced this, and might have a solution I haven’t tried.
Cheers
