Are there any smart switches witch can work with no RF or Wi-Fi but with powerline (network through electricity cables)?
I use sonoff but I am looking if there is a way to have lower emf radiation.
UPB and X10 are powerline only protocols. Insteon is as well if you don’t buy the “dual band” ones.
Thanks for the reply and information.
Have you tested any of these devices?
All of my lights are Insteon, I use an ISY hub. My old house was X10 but it is highly unreliable. I have not used UPB.
Realize that with powerline protocols communication may not work across phases. Insteon uses two RF modules to bridge the phases, I don’t think you can buy hardwired phase couplers for Insteon anymore. I believe UPB sends a spike that is strong enough to cross phases at the transformer in some cases, but you may need a phase coupler if the signal can’t cross or the transformer is too far away.
Other possibility would be LAN, i guess? Not sure about available products, but worth checking…
Thank you again for the information.
I looked at https://www.insteon.com but most products write “dual band” - how i can find only “non - dual band” ?
Its nice that there is an option with RF modules to bridge the phases.
I searched a bit - still havent found solutions…
Other posibility would be a central switchboard, that manages the wires going to your outlets. It’s the hard way (rewiring), but if wireless is a no go, something like this is an option…
(no experience here, just an example)
https://smart-home.ehouse.pro/ehouse-lan/ehouse-lan-smart-home-mini-switchboard/
