Powerpal smart energy monitor
Hi Team,
I have been having fun getting into ESP32 for this project. I have a PowerPal that is too far from the home so using an ESP32 Atom Lite that’s half way between the PowerPal and the Home to connect and push the data back into HomeAssistant.
So far I have been able to sort it out with the M5Stack Atom Lite and its working. I have a couple of M5Stack Nano C6 ESP32 devices which I was keen to try and replace. This unit supports WiFi 6 802.11ax (2.4ghz) and has bluetooth, thread, zigbee radios etc.
The issue I am running into is that the Nano C6 uses the ESP-IDF framework not the Arduino framework. When I try and compile, the powerpal_ble component fails with the following error:
Compiling .pioenvs/nanoc6/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/nanoc6/src/esphome/components/powerpal_ble/powerpal_ble.cpp.o
Compiling .pioenvs/nanoc6/src/esphome/components/remote_base/abbwelcome_protocol.cpp.o
src/esphome/components/powerpal_ble/powerpal_ble.cpp:4:10: fatal error: WiFi.h: No such file or directory
* Looking for WiFi.h dependency? Check our library registry!
* CLI  > platformio lib search "header:WiFi.h"
* Web  > https://registry.platformio.org/search?q=header:WiFi.h
    4 | #include "WiFi.h"
compilation terminated.
*** [.pioenvs/nanoc6/src/esphome/components/powerpal_ble/powerpal_ble.cpp.o] Error 1
In file included from src/esphome/components/remote_base/remote_base.h:12,
                 from src/esphome/components/remote_base/abbwelcome_protocol.h:5,
                 from src/esphome/components/remote_base/abbwelcome_protocol.cpp:1:
/data/cache/platformio/packages/[email protected]/components/driver/deprecated/driver/rmt.h:18:2: warning: #warning "The legacy RMT driver is deprecated, please use driver/rmt_tx.h and/or driver/rmt_rx.h" [-Wcpp]
   18 | #warning "The legacy RMT driver is deprecated, please use driver/rmt_tx.h and/or driver/rmt_rx.h"
========================= [FAILED] Took 26.93 seconds =========================
Is there any way to compile the build using ESP-IDF component?
When I was looking into the best framework to run Bluetooth BLE on ESP32 it also stated the ESP-IDF framework was best, specifically this:
The ESP32 Platform component should be configured to use the esp-idf framework, as the arduino framework uses significantly more memory and performs poorly with the Bluetooth proxy enabled. When switching from arduino to esp-idf , make sure to update the device with a serial cable as the partition table is different between the two frameworks as Over-the-Air Updates updates will not change the partition table.
Wondering if anyone can help? Particularly @muneeb1990 as I think your fork of the original component is what everyone is using?
Thanks team :slight_smile:
This is such a brilliantly simple solution! Well done! :clap:
Hi All,
Anyone have experience as to why the Daily Energy and Pulses goes to extreme values when the ESP32 device is restarted? If I wait till the next day, the energy monitoring works well, however a restart (like below) absolutely throws out the readings.
Below are some content from the logs on the ESP32 device (M5Stack Atom Lite)?
[19:04:48][C][powerpal_ble:013]: POWERPAL
[19:04:48][C][powerpal_ble:014]:  Battery 'Powerpal Battery'
[19:04:48][C][powerpal_ble:014]:    Device Class: 'battery'
[19:04:48][C][powerpal_ble:014]:    State Class: ''
[19:04:48][C][powerpal_ble:014]:    Unit of Measurement: '%'
[19:04:48][C][powerpal_ble:014]:    Accuracy Decimals: 0
[19:04:48][C][powerpal_ble:015]:  Power 'Powerpal Power'
[19:04:48][C][powerpal_ble:015]:    Device Class: 'power'
[19:04:48][C][powerpal_ble:015]:    State Class: 'measurement'
[19:04:48][C][powerpal_ble:015]:    Unit of Measurement: 'W'
[19:04:48][C][powerpal_ble:015]:    Accuracy Decimals: 0
[19:04:48][C][powerpal_ble:016]:  Daily Energy 'Powerpal Daily Energy'
[19:04:48][C][powerpal_ble:016]:    Device Class: 'energy'
[19:04:48][C][powerpal_ble:016]:    State Class: 'total_increasing'
[19:04:48][C][powerpal_ble:016]:    Unit of Measurement: 'kWh'
[19:04:48][C][powerpal_ble:016]:    Accuracy Decimals: 3
[19:04:48][C][powerpal_ble:017]:  Total Energy 'Powerpal Total Energy'
[19:04:48][C][powerpal_ble:017]:    Device Class: 'energy'
[19:04:48][C][powerpal_ble:017]:    State Class: 'total_increasing'
[19:04:48][C][powerpal_ble:017]:    Unit of Measurement: 'kWh'
[19:04:48][C][powerpal_ble:017]:    Accuracy Decimals: 3
[19:04:48][C][wifi_signal.sensor:010]: WiFi Signal 'RSSI'
[19:04:48][C][wifi_signal.sensor:010]:   Device Class: 'signal_strength'
[19:04:48][C][wifi_signal.sensor:010]:   State Class: 'measurement'
[19:04:48][C][wifi_signal.sensor:010]:   Unit of Measurement: 'dBm'
[19:04:48][C][wifi_signal.sensor:010]:   Accuracy Decimals: 0
[19:04:48][C][wifi_info:010]: WifiInfo IPAddress 'IP Address'
[19:04:48][C][wifi_info:012]: WifiInfo SSID 'Connected SSID'
[19:04:48][C][wifi_info:013]: WifiInfo BSSID 'Connected BSSID'
[19:04:48][C][wifi_info:015]: WifiInfo DNS Address 'DNS Address'
[19:04:48][C][wifi_info:010]: WifiInfo IPAddress 'My IP Address'
[19:04:48][C][homeassistant.sensor:030]: Homeassistant Sensor 'ha_daily_pulses'
[19:04:48][C][homeassistant.sensor:030]:   State Class: ''
[19:04:48][C][homeassistant.sensor:030]:   Unit of Measurement: ''
[19:04:48][C][homeassistant.sensor:030]:   Accuracy Decimals: 1
[19:04:48][C][homeassistant.sensor:031]:   Entity ID: 'sensor.powerpal_daily_pulses'
[19:04:48][D][text_sensor:064]: 'M5Stack Atom Lite Uptime': Sending state '0d 00h 31m 50s'
[19:05:03][D][esp32_ble_client:110]: [0] [F8:38:6A:21:7B:F5] ESP_GATTC_NOTIFY_EVT
[19:05:03][D][powerpal_ble:379]: [F8:38:6A:21:7B:F5] Received Notification
[19:05:03][D][powerpal_ble:390]: Recieved measurement notify event
[19:05:03][D][powerpal_ble:049]: Meaurement: DEC(20): 0xf09977671a000020dc5700200090d003ff00ffff
[19:05:03][I][powerpal_ble:064]: Timestamp: 1735891440, Pulses: 26, Average Watts within interval: 1560.000000 W, Daily Pulses: -2147482324
[19:05:03][D][sensor:094]: 'Powerpal Power': Sending state 1560.00000 W with 0 decimals of accuracy
[19:05:03][D][sensor:094]: 'Powerpal Cost_json': Sending state 0.00000  with 11 decimals of accuracy
[19:05:03][D][sensor:094]: 'Powerpal Pulses_json': Sending state 26.00000  with 0 decimals of accuracy
[19:05:03][D][sensor:094]: 'Powerpal Watt Hours_json': Sending state 26.00000  with 0 decimals of accuracy
[19:05:03][D][sensor:094]: 'Powerpal Timestamp_json': Sending state 1735891456.00000  with 0 decimals of accuracy
[19:05:03][D][sensor:094]: 'Powerpal Total Energy': Sending state 1.35100 kWh with 3 decimals of accuracy
[19:05:03][D][sensor:094]: 'Powerpal Daily Energy': Sending state 2147485.00000 kWh with 3 decimals of accuracy
[19:05:03][D][sensor:094]: 'Powerpal Daily Pulses': Sending state 2147484928.00000  with 0 decimals of accuracy
[19:05:03][W][component:237]: Component esp32_ble took a long time for an operation (119 ms).
[19:05:03][W][component:238]: Components should block for at most 30 ms.
[19:05:28][D][sensor:094]: 'Free Memory': Sending state 53.00000 kB with 1 decimals of accuracy
[19:05:29][D][internal_temperature:092]: Ignoring invalid temperature (success=0, value=53.3)
[19:05:40][I][ble_rssi_sensor:049]: ESP_GAP_BLE_READ_RSSI_COMPLETE_EVT RSSI: -85
[19:05:40][D][sensor:094]: 'Powerpal BLE RSSI': Sending state -85.00000 dBm with 0 decimals of accuracy
[19:05:43][D][sensor:094]: 'RSSI': Sending state -79.00000 dBm with 0 decimals of accuracy
[19:05:45][D][sensor:094]: 'uptime_s': Sending state 1970.44702 s with 0 decimals of accuracy
[19:05:48][D][text_sensor:064]: 'M5Stack Atom Lite Uptime': Sending state '0d 00h 32m 50s'
[19:06:03][D][esp32_ble_client:110]: [0] [F8:38:6A:21:7B:F5] ESP_GATTC_NOTIFY_EVT
[19:06:03][D][powerpal_ble:379]: [F8:38:6A:21:7B:F5] Received Notification
[19:06:03][D][powerpal_ble:390]: Recieved measurement notify event
[19:06:03][D][powerpal_ble:049]: Meaurement: DEC(20): 0x2c9a776719000020dc5700200090d003ff00ffff
[19:06:03][I][powerpal_ble:064]: Timestamp: 1735891500, Pulses: 25, Average Watts within interval: 1500.000000 W, Daily Pulses: -2147482298
[19:06:03][D][sensor:094]: 'Powerpal Power': Sending state 1500.00000 W with 0 decimals of accuracy
[19:06:03][D][sensor:094]: 'Powerpal Cost_json': Sending state 0.00000  with 11 decimals of accuracy
[19:06:03][D][sensor:094]: 'Powerpal Pulses_json': Sending state 25.00000  with 0 decimals of accuracy
[19:06:03][D][sensor:094]: 'Powerpal Watt Hours_json': Sending state 25.00000  with 0 decimals of accuracy
[19:06:03][D][sensor:094]: 'Powerpal Timestamp_json': Sending state 1735891456.00000  with 0 decimals of accuracy
[19:06:03][D][sensor:094]: 'Powerpal Total Energy': Sending state 1.37600 kWh with 3 decimals of accuracy
[19:06:03][D][sensor:094]: 'Powerpal Daily Energy': Sending state **2147485.00000 kWh** with 3 decimals of accuracy
[19:06:03][D][sensor:094]: 'Powerpal Daily Pulses': **Sending state 2147484928.00000**  with 0 decimals of accuracy
[19:06:03][W][component:237]: Component esp32_ble took a long time for an operation (125 ms).
[19:06:03][W][component:238]: Components should block for at most 30 ms.
Below is the ESP32 Config:
ESP32 Config
substitutions:
esphome:
  friendly_name: "m5_proxy"
  on_boot:
    then:
      - lambda: |-
           id(powerpal_ble_sensor)->daily_pulses_ = id(powerpal_daily_pulses_backup);
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "[redacted]"
ota:
  - platform: esphome
    password: "[redacted]"
wifi:
  ssid: !secret wifi_ssid
#  ap:
#    ssid: "M5-Proxy Fallback Hotspot"
#    password: "[redacted]"
external_components:
  - source:
     type: git
     url: https://github.com/muneeb1990/esphome
     ref: powerpal_ble
    components: [ powerpal_ble ]
time:
  - platform: homeassistant
bluetooth_proxy:
  active: true
esp32_ble_tracker:
ble_client:
  - mac_address: F8:38:6A:21:7B:F5 #PUT YOUR MAC ADDRESS HERE - NO QUOTES IS IMPORTANT
switch:
  - platform: restart
    name: "Powerpal Monitor Reboot"
globals:
  - id: powerpal_daily_pulses_backup
    type: int
    restore_value: true
  - platform: powerpal_ble
    ble_client_id: powerpal
    power:
    daily_energy:
      name: "Powerpal Daily Energy"
    daily_pulses:
      name: "Powerpal Daily Pulses"
    energy:
      name: "Powerpal Total Energy"
    battery_level:
    watt_hours:
       name: "Powerpal Watt Hours_json"
    cost:
       name: "Powerpal Cost_json"
    timestamp:
       name: "Powerpal Timestamp_json"
    pulses:
       name: "Powerpal Pulses_json"
    pairing_code: 829630 #PUT THE PAIRING CODE FOUND WITH YOUR POWERPAL HERE
    notification_interval: 1
    pulses_per_kwh: 1000
    #http_request_id: powerpal_cloud_uploader
    time_id: homeassistant_time # daily energy still works without a time_id, but recommended to include one to properly handle daylight savings, etc.
    #cost_per_kwh: 0.30 #dollars per kWh
    entity_id: sensor.powerpal_daily_pulses
    on_value:
     then:
       - globals.set:
          value: !lambda 'return int(x);'
    icon: mdi:memory
    lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL) / 1024;
    unit_of_measurement: 'kB'
    state_class: measurement
    entity_category: "diagnostic"
 # - platform: uptime
 #   name: Uptime
 #   id: sys_uptime
  - platform: wifi_signal
  - platform: internal_temperature
    name: "Internal Temperature"
  - platform: uptime
    update_interval: 60s
  - platform: ble_client
    type: rssi
    name: "Powerpal BLE RSSI"
text_sensor:
    name: "M5Stack Atom Lite Uptime"
    lambda: |-
      uint32_t dur = id(uptime_s).state;
      int dys = 0;
      int hrs = 0;
      int mnts = 0;
      if (dur > 86399) {
        dys = trunc(dur / 86400);
        dur = dur - (dys * 86400);
      if (dur > 3599) {
        hrs = trunc(dur / 3600);
        dur = dur - (hrs * 3600);
      if (dur > 59) {
        mnts = trunc(dur / 60);
        dur = dur - (mnts * 60);
      char buffer[17];
      sprintf(buffer, "%ud %02uh %02um %02us", dys, hrs, mnts, dur);
      return {buffer};
    icon: mdi:clock-start
  - platform: wifi_info
    ip_address:
    ip_address:
      name: "My IP Address"
    mac_address:
      name: "My Mac Wifi Address"
    ssid:
    bssid:
    dns_address:
So I managed to fix the issue with a bit of help from Claude AI.
I removed the Friendly Name so that the sensor name for the daily pulse backup is correct in HomeAssistant. I have also updated the following in my ESP Configuration YAML:
Might be useful for someone with the same issue in the future.
esphome:
  on_boot:
      then:
        - lambda: |-
             uint32_t stored_pulses = id(powerpal_daily_pulses_backup);
             if (stored_pulses > 100000) {  // Reasonable maximum for daily pulses
               stored_pulses = 0;
             id(powerpal_ble_sensor)->daily_pulses_ = stored_pulses;
globals:
    type: uint32_t  # Change from int to uint32_t
    restore_value: true
    initial_value: '0'  # Add initial value
    internal: true
    filters:
      - filter_out: nan
    on_value:
      then:
        - globals.set:
            value: !lambda |-
              if (isnan(x) || x < 0 || x > 100000) {
                return id(powerpal_daily_pulses_backup);
              return (uint32_t) x;
This is likely a flat battery in your PowerPal. They’ll replace it for free, though you might need to display app screenshots showing the disconnections. First time mine happened, it we’d dropping out for hours at a time every few days, then daily, then multiple days would go missing and it could grab a little more. Seemed very odd to me, they diagnosed it as flat battery immediately and sent a replacement.
I’m due for my 4th PowerPal early this year. I don’t know how long they’ll continue replacing them, but indefinitely is not the likely answer.
For anyone curious, they’re rated for 1yr but from my experience between 9mths - 14mths is the norm.
But get ready to deploy your own pulse readers, because PowerPal must have an EOL date. Support know me by now, I might. See it I can get anything out of them
New chip isn’t going to resolve your issues so long as you continue using BT you’ll be bound by its limitations (along with each of the technology on the new chip, non of which offer an outstanding improvement .
LoRA is the IoT go to for long range transmission or 433MHz I believe can give up to 100m LoS but isn’t really it’s key feature, it’s transmission through obstacles. Third option would be a point to point wireless link, depending on distance though 20ghz satellites will get costly, but are good for many kilometres with good alignment.
There certainly are options, though I’m unsure what you’re intending to resolve with the new chip…
All ESP use the ESP IDF… The people who make the chip provide the framework for communicating with the chip. The fact that Arduino is possible is become someone writes the necessary for Arduino. Now ESP function has nothing to do with Arduino, it simply hides the lower level development IDE making it accessible to more users.
You want the ESP SDK along with the ESP IDE. I must say however, if you weren’t already aware of this, you may find it rather difficult to get setup and operational. It’s not Arduino - there’s a reason Arduino succeeded at entering the consumer marketplace, and I believe that lies solely within the IDE and its ability to support so many different MCU through a single easy to use interface.
I must ask though - under what circumstances/deployment is not within
Hi… I have had my powerpal for probably 2.5 years, it still shows battery at about 97%.
I did get a newer esp32 wit USBC and it seems to be better, however as I mentioned back in March 24, when it is a warm/hot day it seems to not like it as it has gone offline this morning.
It did this the last few times the weather got over 30, and it happened in the morning when the sun is in the east as that is where it faces …
I should probably get a new one soon. Since you seem to know them @nasha do you know the website/phone number for them…
Hi all,
HA told me I should upgrade my ESPHome, but after going through the upgrade process for other implementations successfully, I get an error on the PowerPal one using @WeekendWarrior1 Github. Doesn’t look like it has been updated for a while.
Here is the error:
INFO ESPHome 2025.2.2
INFO Reading configuration /config/esphome/powerpal-esp32.yaml...
INFO Detected timezone 'Australia/Sydney'
INFO Generating C++ source...
INFO Compiling app...
Processing powerpalble (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Update @ 2.0.0
Compiling .pioenvs/powerpalble/src/esphome/components/ble_client/ble_client.cpp.o
Compiling .pioenvs/powerpalble/src/esphome/components/logger/logger.cpp.o
In file included from src/esphome/components/ble_client/ble_client.cpp:5:
src/esphome/components/ble_client/ble_client.h:89:8: error: conflicting return type specified for 'virtual void esphome::ble_client::BLEClient::gattc_event_handler(esp_gattc_cb_event_t, esp_gatt_if_t, esp_ble_gattc_cb_param_t*)'
   void gattc_event_handler(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if,
In file included from src/esphome/components/ble_client/ble_client.cpp:4:
src/esphome/components/esp32_ble_tracker/esp32_ble_tracker.h:171:16: note: overridden function is 'virtual bool esphome::esp32_ble_tracker::ESPBTClient::gattc_event_handler(esp_gattc_cb_event_t, esp_gatt_if_t, esp_ble_gattc_cb_param_t*)'
   virtual bool gattc_event_handler(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if,
*** [.pioenvs/powerpalble/src/esphome/components/ble_client/ble_client.cpp.o] Error 1
========================== [FAILED] Took 1.88 seconds ==========================
Here is my Yaml:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
  - source: github://WeekendWarrior1/esphome@powerpal_ble
    # requires ble_client because I had to add some small features to authenticate properly
    components: [ ble_client, powerpal_ble ]
logger:
api:
ota:
- platform: esphome
wifi:
# optional requirement to enable powerpal cloud uploading
#http_request:
#  id: powerpal_cloud_uploader
# optional requirement used with daily energy sensor
time:
esp32_ble_tracker:
ble_client:
  - mac_address: A6:68:9F:D3:23:33
    power:
    daily_energy:
    energy:
    battery_level:
    pairing_code: 402169
#    http_request_id: powerpal_cloud_uploader
#    cost_per_kwh: 0.1872 #dollars per kWh
#    powerpal_device_id: 0000abcd #optional, component will retrieve from your Powerpal if not set
#    powerpal_apikey: 4a89a298-b17b-23e7-a6c1-fcd1412e98ef #optional, component will retrieve from your Powerpal if not set
Thanks for any assistance…
Andrew.
I managed to get it working for a few days by setting the framework version, but it was flaky and stopped working again last night. Not sure if related, busy investigating.
esp32:
  framework:
    type: arduino
    version: "2.0.15"
Edit:
I think my problems might be battery related on the unit. I connected the app to it, restarted everything and now it seems to be working again.
I think if you upgraded ESPHome then all you need to do is pin the framework version and you should be good.
Mine stopped working two days ago. It had been working well since October 2023. I tried the version trick. No luck. How do you know if the unit’s battery is flat?
It has come good. I updated the external component to:
github://whitty/emerald_ble@emerald_ble
and it still didn’t work. I then tried pairing with my phone without success. And it started working again. -_- It may have been the battery getting low. I got no idea.
Did you end up working this out - I’ve just tried for the first time, and got the same error.
After a few attempts at getting this up and running I finally found a config that works, so I thought I’d share the steps and yaml file that worked for me.
I am by no means an expert on this, just sharing what I’ve cobbled together from this thread and some AI assistance for anyone wanting to pick this up in May 2025.
I had my powerpal registered and setup in the android powerpal app, which provides the MAC address and pairing code in the settings, along with the pulse per kwh. So if you have the app setup, it’s an easy way to source all the information you need to get the yaml below working correctly.
Please note I’ve used an ethernet enabled esp32 board, so your esp32 config will look a little different if using wifi (like I imagine most people would be). I used ESPHome Builder v2025.4.2 to compile the code and same version on the ESP board iteself.
If you’re connected to the powerpal device on your phone, make sure you turn off bluetooth to enable your esp board to connect (I’ve read that the powerpal device uses bluetooth LE which apparently only supports 1 connection at a time). After I flashed the board and turned off bluetooth on my phone, the powerpal entities started flowing through to home assistant pretty much straight away.
I’m still testing the data for each sensor to make sure it’s configured correctly.
Here’s the esphome config that worked for me:
esphome:
  on_boot:
      then:
        - lambda: |-
esp32:
  board: wt32-eth01 # I'm using an ethernet espboard- update this to suit your model.
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: "" # enter your key between the quotation marks here
ota:
  - platform: esphome
    password: "" # enter your password between the quotation marks here
ethernet: # note this config is for my ethernet based esp32 board- not required to run powerpal
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO0_IN
  phy_addr: 1
  power_pin: GPIO16
    power:
    daily_energy:
    daily_pulses:
    energy:
    battery_level:
    watt_hours:
    cost:
    timestamp:
    pulses:
    pairing_code: XXXXXX # PUT THE PAIRING CODE FOUND WITH YOUR POWERPAL HERE- this is available in the powerpal app.
    pulses_per_kwh: 3200 # can find this in the powerpal app settings
    cost_per_kwh: 0.426976 # dollars per kWh
    on_value:
     then:
       - globals.set:
  - source:
     type: git
     url: https://github.com/muneeb1990/esphome.git
     ref: powerpal_ble
time:
esp32_ble_tracker:
ble_client:
  - mac_address: XX:XX:XX:XX:XX:XX #PUT YOUR MAC ADDRESS HERE - NO QUOTES IS IMPORTANT- you can find the MAC Address in the powerpal app
switch:
  - platform: restart
globals:
    type: int
    restore_value: true
is anyone else having issues with 2025.5? my esp32 is getting stuck in bootloop
I’m looking for some help before I give up trying to integrate Powerpal to Home Assistant OS. I have this running on a Virtual Machine inside my Synology because that was the only way I could mount a Bluetooth receiver - I am not very procifient with coding and ESP32 looks too challenging for me.
I’ve only managed to get the API key using my PC but otherwise, have failed in attempt to get Home Assistant to recognise it. The bluetooth dongle is working properly as I have a few BThome sensors that can be detected and other random nonsense like my toothbrush.
I’ve set up the Powerpal using the app on my android and have then disconnected it from my phone but Home Assistant does not recognise it. I’ve also let the app run on the phone and tried to use the integration tool by mindmelting.
Any ideas?
TIA
Your best bet is to use a dedicated ESP32 board to connect to Powerpal. Mine hasn’t missed a beat for 2 years now and even survived a couple of short power outages.
From my research, the technical knowledge is honestly above my skills but I’m happy to try. Any good guides/resources you can recommend? Besides buying the ESP32 board, I wouldn’t even know how to connect it to power.
I have had some limited success in using the ESP32 as a bluetooth proxy. I can, finally see that the Powerpal is being detected but otherwise, have no idea how to intergrate that into the dashboard itself. I have used the code by acenumber22 above but no entities are showing up.
did you ever figure this out?
Heads up - looks like this stopped working after upgrading from ESPHome 2025.5.2 to 2025.6.0 - received an error message on the first reboot after restarting:
[W][esp32_ble:417][BTC_TASK]: Ignoring unexpected GAP event type: 8
Further restarts are just giving this in the logs:
> [D][esp32_ble_tracker:343]: End of scan, set scanner state to IDLE.
> [D][esp32_ble_tracker:307]: Starting scan, set scanner state to STARTING.
(Maybe related to the BLE issue described here? 2025.6-beta3: Can not query BLE signal strength · Issue #7127 · esphome/issues · GitHub)
