Prediction: The probability of YoLink releasing a “local” hub by January 1, 2025, is 10%
Prediction: The probability of YoLink releasing a “local” hub by January 1, 2025, is 10%.
The rationale for this prediction has 5 parts.
  1. YoLink products are now available at Home Depot, Lowes and Walmart. These are high volume retail distribution channels with a broad customer base. The customer base is not sufficiently sophisticated to see the advantage of local vs cloud architecture. YoLink is selling into the broad retail market, not the hobbyist market.
  2. YoLink is no longer supporting Discord, Reddit, and Home Assistant forums. YoLink’s forum facing presence, Eric, has disappeared and has not been replaced. The population that inhabits these forums is no longer YoLink’s marketing target.
  3. The return on investment for developing a local hub is unclear. The demand for a local hub is limited to a small, albeit sophisticated, market. The development effort seems to me, from the outside, to be more than a few months to less than a year.
  4. Providing a local hub to the retail market would places YoLink in the position of supporting two different architectures. Supporting a local hub will increase expenses.
  5. YoLink has not released local hub specifications or a delivery date. The specifications, development, test, fabrication, test, documentation cycle for a commercial product is typically lengthy. Yes, YoLink said they were going to develop a local hub, but ….
    There are individuals on this forum that are anxiously awaiting a local hub. My prediction is that this is not going to happen.
I am impressed by YoLink products, so I did “due diligence” on YoSmart and YoLink. The results were rather opaque. The address of YoLink, 25172 Arctic Ocean Drive Ste 106, Lake Forest, California 92630 looks like a mail drop. A google search on the address returned several companies with the same address. When I attempted to pull a D&B credit report on YoSmart and YoLink, D&B did not have records on either company. The YoLink web site contains the description “YoLink, a division of YoSmart, a US corporation based in Irvine, California, ….”
My YoLink investment is small, a few hundred dollars and it works so I am going to keep using it.
I hope this is interesting. I am going to cross-post this on Home Automation, Reddit and Discord.
From hub3 page:
As of April 2024, the YoLink Hub 3 does not support local integration. It is planned to be completed by end of year along with matter compatibility and once completed, will be through a software update by the Hub 3.
I’ve been checking every couple of months and wanted to add a couple observations.
In reply to 3 & 4 - by adding support for matter, they gain the attention of a growing audience of consumers who value interoperability. The HomeAssistant integration would become redundant at this point, so they could likely drop support for it (whatever minimal support exists).
Regarding hub 3 - there is a glaring problem which remains unaccounted for, if my understanding of the current architecture is correct.
Following is my personal speculation:
My limited understanding is the existing protocol uses the hubs as simple border routers, meaning they do not have knowledge of the message contents or a way to check validity. This seems like a reasonable design, as it’s more secure if the private keys are not distributed into the field at all. Thus it is not possible to replay messages or snoop the contents, or issue a fake firmware, among other concerns which could spell trouble for the whole product line if messed up. It also has the advantage of expanding reliability and coverage, since any hub within range can forward messages to the cloud.
With matter or local control, the whole situation changes. There are tradeoffs, but ideally, they want to keep the existing level of coverage and not pair the sensors to a specific hub. Thus you could have multiple hubs forwarding messages to HomeAssistant, and the messages can be deduplicated easily with a sequence number.
Option A - The hidden complexity is whether to implement matter at the sensor level - in which case end to end encryption is possible with HomeAssistant (the hub needs no knowledge of the message contents). This is a really simple way to handle key distribution, since it effectively operates the same as it would in the cloud. It’s a straight forward implementation where HomeAssistant actually pairs directly with the sensors.
Option B - If they want to take a shortcut then they can try to implement matter at the hub only, with minimal changes to sensor firmware. But the time saving is replaced with the complexity of distributing keys to the hubs in a secure manner, and the associated pairing process which currently exists only for devices with “D2D support”. By allowing the hub to open messages, they are risking the possibility of a huge breach where a method is found to extract or replace a key on the hub, or any other security flaw, thus compromising any/all customers in the general case. It’s a lot of hoops to jump through and a lot of possible flaws or attack vectors to account for since each hub is effectively a target. Whereas previously the consequences of a compromised hub are less severe, with less attack surface area in the first place.
Option C - they can try to retrofit a mesh network, or just forego the coverage entirely if using matter and rely on only one hub / some compromise of the above.
Option D - customer managed PKI - the could essentially give customers a docker image of the YoLink cloud infrastructure, assuming licensing and intellectual property concerns are accounted for, and “release” the devices from the cloud, effectively orphaning them. This is the option which would serve only HomeAssistant type users, and makes least business sense.
Politics of the decision to add local support are (hopefully) taking a back seat to the security concerns, and the ROI has to take the possibility of bad press/bricked devices/threat actors into account. If Matter and mesh support existed from the beginning then this wouldn’t be a hard ask.
The upside of a proper and secure Matter implementation is that going forward, the YoLink app does not need to continue reinventing the wheel regarding new features which have overlap in other platforms. Essentially it would be like having “10% off” on their cloud bill, if data exchange for Matter enabled devices is kept local only. It’s a write once / reuse situation if they get it right on the first try. But it is also like changing the tires on a moving car and then having to send it in for crash certification and safety ratings due to the size and scope of the change. Not without risk.
So, since we are about to go into December I decided to ask their support what the status was on their claim that their Hub 3 would have Matter & Local API support by the end of the year.
I was just told that Matter support has been delayed and they would be releasing a new hub in December with local API support.
SMH
Believe nothing this company promises.
Add to that their website is even still making this claim, so they are literally selling hubs with this already-false promise.
I asked them back in October when I noticed their new Hub called the X3. I asked them if that was the new Matter/Local hub and they said no it wasn’t. But they told me what they told you. That a new hub with local API would be out before the end of the year.
As a non technical HA user, do we need Matter? Isn’t having a local API good enough for us? I mean as long as our devices work locally through a Yolink integration then it shouldn’t matter to us if Matter integration isn’t ready yet, right?
Anyways they have 4 weeks left to fulfill the promise of a new hub and the local API. I really hope they do that because I’ve taken down half my Yolink sensors and replaced them with Zigbee variants. But I really want to put the Yolink stuff back. I just need a good reason to.
Matter is already implemented in home assistant, whereas even their cloud integration fails to expose things like the ability to program their door locks. I have 0 confidence they won’t handicap the local API just like they did the cloud integration. Not to mention their current integration doesn’t support any local API, and they haven’t made any promises about updating it to do so.
Can we update the title please?
Prediction: The probability of YoLink releasing a “local” hub by January 1, 2025, is 0.1%
The probability that a company let’s you out of their vendor lock is 0.00%
At this point I am steering others away from YoLink. I’m hoping for alternatives on the horizon like a solid ESPNow implementation or a different LoRa family of hobbyist oriented options. For any switches - the Tasmota or OpenBeken firmware is way faster and the hardware is way better.
For contacts and motion sensors - I already had a QolSys IQ4 alarm panel which supports the DSC “PowerG” sensors, which are 2-way encrypted with “up to 4km range” in the open air, and similar power efficiency as the YoLink stuff. Most of my sensors are the legacy ones without encryption. I was able to get it working tonight with HomeAssistant via the Control4 integration method since I own the panel and it is monitored with Surety (they are strictly bring your own equipment).
Hence the Tasmota and QolSys panel combination seems like a comprehensive replacement for the YoLink stuff I was using. The alarm panel is acting as a local hub. So basically, any door that had a security tag on it will have one fewer YoLink tag now :smile:
The QolSys panel in general also supports legacy unencrypted sensors, which can be acquired cheaply, and there are a number of “takeover” modules which can report wired zones to the panel, and by proxy, Home Assistant. So I am excited to finish wiring up the physical contacts left by the previous home owner which I could not use previously with YoLink, or would have had to build an ESPHome device to bring into Home Assistant. Similar for 2gig or other sensors probably, since they all try to steal each others’ customers, there are options for “translators.”
Used IQ2 panels can sometimes be found cheap, and work also. You don’t have to pay for monitoring service if you come across one. You will need the dealer code/installer code, and a set of contacts with a compatible frequency or translator. Just pay attention what radio is installed on the panel and get contacts of the same family. Put it somewhere physically central (or possibly add a repeater if not using PowerG), and enjoy the myriad of cheap sensors available. If you do go with monitoring service, then you get cellular backup along with the wifi connection for the panel.
Crediting the hard work by these people:
https://www.reddit.com/r/homebridge/comments/zz2tbk/psa_alarmcomqolsys_users_we_finally_have_local/
Happy(ier) New Year!
Something is cooking :shushing_face:
I have been adding some yolink stuff. Probably not a good idea considering the state of things as mentioned in this thread. But man, I really like the things I have added. I really want to keep going.
Maybe we just need to bombard them with requests for Matter or at least a local API! I am no programmer so I can’t pretend to understand the complexities but other companies have been able to release a Matter hub with all existing sensors working without issue. Fingers crossed.
Also, I need someone to explain to me like I’m 5 how to build yolink into a workable security alarm system lol. Is there no way to “arm” the system other than running the Away scene? Seems unnecessarily complicated. And a keypad would be nice but I guess you are meant to just have each person have a fob to activate/deactivate the alarm? Would be nice if a “system” was exposed to HA so we could automate arming and disarming.
Just ask aboul local integration again. There is reply a receved:
quote
Thank you for contacting us.
The Hub 3 was initially expected to support local integration by the end of 2024 >however it was postponed for now as we are preparing to release the new Local >Hub (YS1606) that supports the local network without having to do some firmware >upgrades. Due to the current demands on our R&D team, including the >development of new products and the maintenance of existing ones, the release >has been slightly delayed. The Hub 3 will still be supporting the local network >however we do not have a specific timeline for it yet. Once the new hub is >released, if you currently have the hub 3, you can swap your hub 3 for it and just >pay the difference to have the support for local network without waiting for the hub >3’s upgrade.
We sincerely appreciate your patience and understanding as we work to deliver >this new product. If you have any further questions or concerns, please don’t >hesitate to reach out to us.
Thank you.
Meisha | YoLink Customer Support
Potentially good news everyone!
The Matter/Local-API hub is now in a real product - the “Local Hub” model “YS1606-UC”:
https://www.yosmart.com/support/YS1606-UC/docs/instruction
The above PDF document does include a step for retrieving “Local API Integration” client ID and Secret values, but I have not yet found details of how to integrate the device into HA using these credentials.
Appears there’s a new model number for the LTE hub listed in the PDF document. The current LTE hub is YS1605 and the document lists YS1606-UC.
It’s real, I have provisioned it but it’s fairly broken atm! YoLink integration - #797 by rwojo
I just got the new Local Hub (YS1606-UC). It supports both local API and Matter. Being brand new product I am guessing they still working on fully supporting all their devices and data elements but excited to actually have one in my hands.
Where did you get it? I still don’t see it listed in their store.
I see it on their store, but it’s sold out currently
I do have it but currently it’s paper weight for me. There is still a lot of work to be done. For example Matter will stop working after maybe 4-6 hours and doesn’t support all their devices.
There is no local integration yet either so I’m still using the cloud integration. I think they’ll fix it eventually but it’s going to take some time.
What a success story this brand is :grin:
Promise so much but delivery so little :pinching_hand:
Sorry for the delay. I actually emailed their support team asking if they had any updates on when it was coming. They let me know they just got them in their warehouse and I could order directly with them not using their website.
However as Rice_Eater said it is really in bad shape right now. I sent their support team about a 3 page email with all the issues I identified and all the bugs. I would strongly suggest waiting for them to get everything ironed out.
Not sure if you’re aware but there is a much bigger thread about Yolink and a rep of theirs commented a few weeks ago with an update on what they’re planning on doing about all the current issues
Thankfully most of the issues should be fixed in the next update with a few probably taking a bit more time. No idea when it’s coming, but it should at least be this month.
For now I just want functional Matter support at least. Of course I’d prefer a local API integration but I can wait for that to come later.
