Hi there, i’ve been updating my configs to prep for 0.107.0 and in general cleaning up old configs that i no longer use and no longer supported (old frontend, groups etc)
i have 2 warnings that i can’t track down
"The ‘control’ option (with value ‘hidden’) is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0
The ‘view’ option (with value ‘True’) is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0"
I cannot track down where these might be. I’m probably being OCD, but i hate when i have warnings or errors.
i read in one of the recent release notes that this would be in the groups config, but i’ve thoroughly gone through it and there is no control or view option there
anyone have ideas where these might pop up?
it would be nice if it had the related entity these warnings came from
Sorry, war ein versehen, danke.
But by the way, I do not have such entries neither in groups nor in automation or configuration.yaml.
All what I’ve found is the old default_view in the groups yaml.
I already deleted these entries and will see if the warning during start up still appears.
cheers
understood. i’ll look into using something like that for the future. i’ve been just using simple editors over the past few years and haven’t used a full blown IDE with advanced search features yet
Do it! It’s easy and there’s also an extension for visual studio code to connect to home assistant. This way it will auto-populate entities you have in your system and some other nice features.
If you use Home Assistant (formerly Hass.io) there’s also an add-on to have Visual Studio Code in the browser.
@sparkydave, @a_lunatic, Well … That’s half a step forward.
I run HA on a pi 3 and a pi 4.
The pi 3 runs hassos 32bit (recommended) - I suppose that could be upgraded to hassos 64bit ? Then restore a snapshot.
The pi 4 has an ssd, so runs buster from the sd to load the System from ssd. Buster is (I believe) only currently available in 32 bit form.
Bugger !!!
Actually, it’s pretty convenient running vsc from a workstation as its one instance for both pi’s (test and production) and Im not tempted to run it over a phone or tablet. Cutting and pasting is a nightmare.
