Pressure sensor
Hi folks,
I’m looking to build a sensor to monitor water pressure (1 - 3 bar). I was planning on using a ESP32 with a linear voltage sensor.
Can anyone point me in the direction of a reasonably priced unit. Anything I have found is 100+
Padraic
DIY?
ESPHome and a 4-20mA or 0-3.3V one of these: https://www.aliexpress.com/item/1005008462356803.html
Thanks Tom, looks like what I’m looking for. I had searched aliexpress but didnt find them.
Yes DIY with ESPhome. I was doing some reading on them and believe a voltage input might be easier to manage than a 4-20mA. The article i was reading mention a 4.5v one and usiing a 100 ohm resistor to divide the voltage. Any thoughts?
0-3.3V voltage output is perfect if you don’t have really long wiring (in that case go with 4-20mA or RS485).
4-20mA can be detected with a 150 Ohm resistor (4-20mA → 0.6-3V) or with an INA219 current sensing module.
RS485 would be more complicated.
Do you have a way of calibrating the reading?
Here’s some older stuff - I’m running two of the DFRobot ones ( Gravity: Analog Water Pressure Sensor - DFRobot) connected to a Wemos D1 mini each:
Water Pressure Z-wave - wifi: monitor pressure of city water - Hardware - Home Assistant Community
This may be of interest to folks following this topic:
That’s flow, not pressure. Also until I see some real world tests I’m going to assume it is terribly inaccurate.
I have multiple analogue guages on the same system. Can these be used as reference points to calibrate?
Yep, that would work. See: Sensor Component - ESPHome - Smart Home Made Simple
Did you buy one of the sensors in the end?
Did you complete the project?
Looking for something similar.
I only bought one and arrived last week. I haven’t started into it. Its hard to get time to do everything.
