I’ve been reading about HA non-stop for the last month and have watched countless youtube tutorials. I finally pulled the trigger and got HASS.IO setup on a PI.
Let me say that starting out from scratch has been a steep learning curve. I’ve poured over the documentation on this page and the tasmota guides and think I must have some settings switched up. Can I have one of you guys look at my settings and see what I’ve screwed up?
-The Host matches the IP of my HASSIO PI. (do I need :8123 after the IP? I’ve tried it both ways)
-Port 1183 must be correct from the reading I’ve done
-Client, I’ve left as default
-User should match discovery_prefix in MQTT in configuration.yaml?
-password, matches XXXXXXX in mqtt section of configuration.yaml
Thanks for the reply. I did actually find that post and that didn’t seem to work for me. Under my MQTT Integration it sitll says “This integration has no devices”
I finally got it working! After setting up mosquitto and fiddling with the settings a little more I decided to try updating the tasmota firmware which fixed my problem!
I’m on my way to setting up more devices and creating some utomations! Hooray! Thanks for the help guys!
