Seeing the same behavior on two TZ3000_gjnozsaz on ZHA. It keeps blinking after Home Assistant reports that the pairing is done, and then only works for a few seconds.
Tried on Z2M and it works fine. Updated to the latest firmware from there (app_version from 76 to 192), but still the same issue in ZHA.
Edit: Found this in the logs during paring of the device, not sure if it’s related.
2022-11-14 18:34:43.097 DEBUG (MainThread) [zigpy.appdb] Error handling '_save_attribute' event with (a4:c1:38:1d:fb:3e:92:e4, 1, 0, 4, '_TZ3000_gjnozsaz') params: FOREIGN KEY constraint failed
2022-11-14 18:34:43.108 DEBUG (MainThread) [zigpy.appdb] Error handling '_save_attribute' event with (a4:c1:38:1d:fb:3e:92:e4, 1, 0, 5, 'TS011F') params: FOREIGN KEY constraint failed
Diagnostic:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.11.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Paris",
"os_name": "Linux",
"os_version": "5.15.74",
"supervisor": "2022.10.2",
"host_os": "Home Assistant OS 9.3",
"docker_version": "20.10.18",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"grocy": {
"version": "v4.5.2",
"requirements": [
"pygrocy==1.4.1"
"hacs": {
"version": "1.28.3",
"requirements": [
"aiogithubapi>=22.2.4"
"iaquk": {
"version": "1.6.2",
"requirements": []
"qubino_wire_pilot": {
"version": "2.0.0",
"requirements": []
"adaptive_lighting": {
"version": "1.2.0",
"requirements": []
"zha_toolkit": {
"version": "v0.8.23",
"requirements": [
"packaging>=20.8"
"rte_ecowatt": {
"version": "0.1.1",
"requirements": [
"Async-OAuthlib==0.0.9"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.2",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.85",
"zigpy-deconz==0.19.0",
"zigpy==0.51.5",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.3",
"zigpy-znp==0.9.1"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 30803,
"manufacturer": "_TZ3000_gjnozsaz",
"model": "TS011F",
"name": "_TZ3000_gjnozsaz TS011F",
"quirk_applied": true,
"quirk_class": "zhaquirks.tuya.ts011f_plug.Plug",
"manufacturer_code": 4417,
"power_source": "Mains",
"lqi": 255,
"rssi": -69,
"last_seen": "2022-11-14T17:30:10",
"available": true,
"device_type": "Router",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x010a",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0702",
"0x0b04",
"0xe000",
"0xe001"
"out_clusters": [
"0x000a",
"0x0019"
"active_coordinator": false,
"entities": [
"entity_id": "button.tz3000_gjnozsaz_ts011f_identify",
"entity_id": "select.tz3000_gjnozsaz_ts011f_power_on_state",
"entity_id": "sensor.tz3000_gjnozsaz_ts011f_active_power",
"entity_id": "sensor.tz3000_gjnozsaz_ts011f_rms_current",
"entity_id": "sensor.tz3000_gjnozsaz_ts011f_rms_voltage",
"entity_id": "sensor.tz3000_gjnozsaz_ts011f_power_factor",
"entity_id": "sensor.tz3000_gjnozsaz_ts011f_summation_delivered",
"entity_id": "switch.tz3000_gjnozsaz_ts011f_switch",
"neighbors": [],
"endpoint_names": [
"name": "ON_OFF_PLUG_IN_UNIT"
"user_given_name": null,
"device_reg_id": "0f7c4ef6731e000f4bc859191f811ab1",
"area_id": null,
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_PLUG_IN_UNIT",
"id": 266
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0000": {
"attribute_name": "zcl_version",
"value": 3
"0x0001": {
"attribute_name": "app_version",
"value": 192
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZ3000_gjnozsaz"
"0x0005": {
"attribute_name": "model",
"value": "TS011F"
"0x0007": {
"attribute_name": "power_source",
"value": 1
"0xfffe": {
"attribute_name": "attr_reporting_status",
"value": 0
"unsupported_attributes": {}
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 1
"0x8002": {
"attribute_name": "power_on_state",
"value": 2
"0x4003": {
"attribute_name": "start_up_on_off"
"0x0702": {
"endpoint_attribute": "smartenergy_metering",
"attributes": {
"0x0000": {
"attribute_name": "current_summ_delivered",
"value": 0
"0x0200": {
"attribute_name": "status",
"value": 0
"0x0300": {
"attribute_name": "unit_of_measure",
"value": 0
"0x0301": {
"attribute_name": "multiplier",
"value": 1
"0x0302": {
"attribute_name": "divisor",
"value": 100
"0x0303": {
"attribute_name": "summation_formatting",
"value": 0
"0x0306": {
"attribute_name": "metering_device_type",
"value": 0
"0x0400": {
"attribute_name": "instantaneous_demand"
"0x0304": {
"attribute_name": "demand_formatting"
"0x0b04": {
"endpoint_attribute": "electrical_measurement",
"attributes": {
"0x0505": {
"attribute_name": "rms_voltage",
"value": 237
"0x0508": {
"attribute_name": "rms_current",
"value": 0
"0x050b": {
"attribute_name": "active_power",
"value": 0
"0x0602": {
"attribute_name": "ac_current_multiplier",
"value": 1
"0x0603": {
"attribute_name": "ac_current_divisor",
"value": 1000
"0x0300": {
"attribute_name": "ac_frequency"
"0x0601": {
"attribute_name": "ac_voltage_divisor"
"0x0302": {
"attribute_name": "ac_frequency_max"
"0x0600": {
"attribute_name": "ac_voltage_multiplier"
"0x0604": {
"attribute_name": "ac_power_multiplier"
"0x0605": {
"attribute_name": "ac_power_divisor"
"0x0401": {
"attribute_name": "ac_frequency_divisor"
"0x0507": {
"attribute_name": "rms_voltage_max"
"0x0400": {
"attribute_name": "ac_frequency_multiplier"
"0x0000": {
"attribute_name": "measurement_type"
"0x050a": {
"attribute_name": "rms_current_max"
"0x0403": {
"attribute_name": "power_divisor"
"0x050d": {
"attribute_name": "active_power_max"
"0x050f": {
"attribute_name": "apparent_power"
"0x0402": {
"attribute_name": "power_multiplier"
"0xe000": {
"endpoint_attribute": "tuya_is_pita_0",
"attributes": {},
"0xe001": {
"endpoint_attribute": "tuya_external_switch_type",
"attributes": {},
"out_clusters": {
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
