I am trying to install Home Assistant on a Raspberry PI4 and it gets to the point where it says “Waiting for the Home Assistant CLI to be ready”; [WARN] Home Assistant CLI not starting! Jump into emergency console…
The instructions say:
4. Within a few minutes you will be able to reach Home Assistant on homeassistant.local:8123. If you are running an older Windows version or have a stricter network configuration, you might need to access Home Assistant at homeassistant:8123 or http://X.X.X.X:8123 (replace X.X.X.X with your Raspberry Pi’s IP address).
With the Home Assistant Operating System installed and accessible you can continue with onboarding.
I must be missing a step. I left it for 12 hours as suggested elsewhere but no change. I can see it in my router and it does have an IP address if that makes a difference.
Can someone please please please point me in the right direction?
I am a novice in Linux so please go easy on me…
Yes I saw that. That thread assumes that one has a lot of Linux knowledge I think.
The other thing is that I don’t see anything in that thread that someone has found a solution.
Hoping for a solution from someone in plain English for a Linux novice. I don’t want to try too many things just yet as I may messing it up even worse.
I am well and truly at the bottom of the food chain here.
I dont want to cry ‘poor me’ either, just looking for guidance.
Before doing a new install with an older version, I thought I would try some of the things mentioned in the other thread re. time and date.
For a start, time and date was wrong so I fixed that but the time zone is wrong and I can’t change it. I try: timedatectl set-timezone Australia/Sydney
I get: Failed to set time zone: Failed to set time zone: Read-only file system
AHA!!! After rebooting, I now get a logo of sorts in the terminal window that says:
‘Home Assistant’
Welcome to the Home Assistant command line.
System information with IP address,etc…
All I did was to make sure that time and date was set right (I messed the time up a little the first time) and rebooted and it came up OK.
I never managed to change the time zone due to the Read-only but it seems that its not needed.
Once the Onboarding process starts, there is a field where the location is set anyway so I guess it gets the time zone from there.
