Hello
I am using home-assistant with the variable component since a year without problem. But when I try to upgrade from HA 0.83.3 to 0.84.3, the variable component breaks and I got the following error:
Dec 17 19:08:22 homeassistant hass[11313]: #033[31m2018-12-17 19:08:22 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.variable. Make sure all dependencies are installed#033[0m
Dec 17 19:08:22 homeassistant hass[11313]: Traceback (most recent call last):
Dec 17 19:08:23 homeassistant hass[11313]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py", line 92, in
get_component
Dec 17 19:08:23 homeassistant hass[11313]: module = importlib.import_module(path)
Dec 17 19:08:23 homeassistant hass[11313]: File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
Dec 17 19:08:23 homeassistant hass[11313]: return _bootstrap._gcd_import(name[level:], package, level)
Dec 17 19:08:23 homeassistant hass[11313]: File "<frozen importlib._bootstrap>", line 986, in _gcd_import
Dec 17 19:08:23 homeassistant hass[11313]: File "<frozen importlib._bootstrap>", line 969, in _find_and_load
Dec 17 19:08:23 homeassistant hass[11313]: File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
Dec 17 19:08:23 homeassistant hass[11313]: File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
Dec 17 19:08:23 homeassistant hass[11313]: File "<frozen importlib._bootstrap_external>", line 673, in exec_module
Dec 17 19:08:23 homeassistant hass[11313]: File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
Dec 17 19:08:23 homeassistant hass[11313]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/variable.py"
, line 14, in <module>
Dec 17 19:08:23 homeassistant hass[11313]: from homeassistant.helpers.restore_state import async_get_last_state
Dec 17 19:08:23 homeassistant hass[11313]: ImportError: cannot import name 'async_get_last_state'#033[0m
Dec 17 19:08:23 homeassistant hass[11313]: #033[31m2018-12-17 19:08:23 ERROR (MainThread) [homeassistant.loader] Unable to find compone
nt variable#033[0m
Dec 17 19:08:23 homeassistant hass[11313]: #033[31m2018-12-17 19:08:23 ERROR (MainThread) [homeassistant.setup] Setup failed for variab
le: Component not found.#033[0m
I am using pip3 install --upgrade homeassistant to upgrade on a raspbian strech
Linux homeassistant 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
Did the new release work with the variable component ?
Thanks for any advice
Marc
