I have used Z-wave for ~5 years and ~4 years with openHAB but now exploring Home Assistant as replacement.
I am using AEON Labs ZW090 Z-Stick Gen5 EU controller.
In order to get familar with Home Assistant I have installed it several times, played with it and reset by reflashing the SD-card.
First time (May 17) after initial config I just plugged in the Z-wave stick and added config
zwave:
usb_path: /dev/ttyACM0
HA discovered a number of Z-wave devices (but not all and one “Unknown”)
Yesterday (May 20) I re-flashed and did the same configuration. Then only the stick itself were discovered and after some time 3 more Z-wave plugs. Got tired of it left it over night.
Today with fresh eyes I shutted down the HA and moved the stick to openHAB and fired it up. All 14 Z-wave devices appeared and “online”.
So re-flashed HA, added Samba and SSH add-ons. Plugged in USB stick, rebooted and configured the integration vi UI this time. No Z-wave devies more that Z-wave stick appears.
Do you have any tricks on how to resolve this
