I am new to Home Assistant.
I have installed Home Assistant on a Rasberry Pi 4b (32Bit).
That runs and everything is fine.
After that, I tried to integrate KNX.
I could not find any normal integration like Home Kit oder Phillips Hue etc.
So I started Googleing and found this:
I tried my best, but everytime I download the files and then rebootet the RP the files were gone.
I have even tried to download them into different folders “~” and “/home”, but it didn’t work.
Am I missing a configuration to save not known files?
Or is this even the right way for KNX integration?
And btw, in that documentation mentiont earlierer they said to run the command “hass”. I can’t execute this command. It says allways not found.
Did I miss something?`
Thanks!
Regards
Christopher
