all my sensor info is unknown. when running
sudo docker exec -it inverter bash -c ‘/opt/inverter-cli/bin/inverter_poller -d -1’
I get the following
Fri Jun 17 20:43:52 2022 INVERTER: Debug set
Fri Jun 17 20:43:52 2022 INVERTER: Current CRC: 49 C1
Fri Jun 17 20:43:55 2022 INVERTER: QMOD read timeout
Fri Jun 17 20:43:55 2022 INVERTER: QMOD reply too short (0 bytes)
Fri Jun 17 20:43:55 2022 INVERTER: Current CRC: B7 A9
Fri Jun 17 20:43:58 2022 INVERTER: QPIGS read timeout
Fri Jun 17 20:43:58 2022 INVERTER: QPIGS reply too short (0 bytes)
Fri Jun 17 20:43:58 2022 INVERTER: Current CRC: F8 54
Fri Jun 17 20:44:01 2022 INVERTER: QPIRI read timeout
Fri Jun 17 20:44:01 2022 INVERTER: QPIRI reply too short (0 bytes)
Fri Jun 17 20:44:01 2022 INVERTER: Current CRC: B4 DA
Fri Jun 17 20:44:04 2022 INVERTER: QPIWS read timeout
Fri Jun 17 20:44:04 2022 INVERTER: QPIWS reply too short (0 bytes)
Fri Jun 17 20:44:09 2022 INVERTER: Current CRC: 49 C1
Fri Jun 17 20:44:12 2022 INVERTER: QMOD read timeout
Fri Jun 17 20:44:12 2022 INVERTER: QMOD reply too short (0 bytes)
Fri Jun 17 20:44:12 2022 INVERTER: Current CRC: B7 A9
Fri Jun 17 20:44:15 2022 INVERTER: QPIGS read timeout
Fri Jun 17 20:44:15 2022 INVERTER: QPIGS reply too short (0 bytes)
Fri Jun 17 20:44:15 2022 INVERTER: Current CRC: F8 54
Fri Jun 17 20:44:18 2022 INVERTER: QPIRI read timeout
Fri Jun 17 20:44:18 2022 INVERTER: QPIRI reply too short (0 bytes)
Fri Jun 17 20:44:18 2022 INVERTER: Current CRC: B4 DA
Fri Jun 17 20:44:21 2022 INVERTER: QPIWS read timeout
Fri Jun 17 20:44:21 2022 INVERTER: QPIWS reply too short (0 bytes)
There is an adapter from serial to USB. You need to buy a good one
Post 503:
You have pdf in fork for understanding warnings. First digit from left if I remember correctly it is reserved. But you should count according pdf. You probably have an error on Inverter.
In my fork you have an example of sensor to put in HA for translate the codes for warnings
Post 505:
I think there is commands for docker for logging in general
And for this exactly you can type - help to see the options for test pulling command
Also may be an issue with my fork for some Inverters because of pulling time to fast causing to freeze the Inverter interface. I have 7 seconds, ned Kelly have 30s. You can clone, or modify locally my fork to test.
I can not post 3 posts consecutively. @icedog what about:
sudo docker exec -it voltronic-mqtt bash -c ‘/opt/inverter-cli/bin/inverter_poller -d -r QPI’
nope friend, my seller say to me that the usb port is unstable, use the rs232 please, i have no disconnection ever.
After you lost connection check if is present or not on the raspberry host the file /dev/hidraw0, if the file is not present, the usb port on the inverter was crashed.
The warning code you say is “PV loss”, see the protocol datasheet to learn how to decode the warning code (page 8) doc below.
What can I do about this “Time out, not OK. Bad connection to Inverter/bad fixed response”
As I’m on a raspberry pi do I need to allow the USB connection through the docker container?
Do I need to try a USB to serial? I do have one that i’m trying but I can’t see it in /dev/ttyUSB0
what am I doing so wrong, I have an Iconica ICMP100012.
this is good and bad in same time.
good because response it is protocol PI30. This program works on this protocol.
bad because I don’t know why it is not working for you.
If you have an rs232 to ttl converter and a esp board you can also try integration from esphome.
any how search this site maybe you will find somebody with a solution.
Hi Andre
I have the same inverter(exactly a clone- Easun IGridSV-IV5.6KW) and a free raspbery py 3 so I could try your setup on my configuration.
I need an image of your inverter py card - maybe on some file sharring.
Maybe others could help on this issue by having an easyer acces to the problem.
Regards
Sorry to keep posting, I have just brought a new serial to usb adapter as I wasn’t seeing ttyUSB0 when using my old cable.
The new cable appears straight away under /dev/
I have completely removed and readded the image and configured the inventer.conf to use ttyUSB0
I’m still seeing unknown in home assistant but when running
I see the following. is there something I’m missing?
The following settings allow you to modify runtime buffers.
N.B. These values may not be applicable to all inverter types, as such you will
need
Sun Jun 19 19:06:56 2022 INVERTER: Current CRC: B7 A9
Sun Jun 19 19:06:59 2022 INVERTER: QPIGS read timeout
Sun Jun 19 19:07:00 2022 INVERTER: QPIGS reply too short (7 bytes)
Sun Jun 19 19:07:00 2022 INVERTER: Current CRC: F8 54
Sun Jun 19 19:07:03 2022 INVERTER: QPIRI read timeout
Sun Jun 19 19:07:04 2022 INVERTER: QPIRI reply too short (7 bytes)
Sun Jun 19 19:07:04 2022 INVERTER: Current CRC: B4 DA
Sun Jun 19 19:07:07 2022 INVERTER: QPIWS read timeout
Sun Jun 19 19:07:08 2022 INVERTER: QPIWS reply too short (7 bytes)
Sun Jun 19 19:07:13 2022 INVERTER: Current CRC: 49 C1
Sun Jun 19 19:07:16 2022 INVERTER: QMOD read timeout
Sun Jun 19 19:07:16 2022 INVERTER: QMOD reply too short (0 bytes)
Sun Jun 19 19:07:16 2022 INVERTER: Current CRC: B7 A9
Sun Jun 19 19:07:19 2022 INVERTER: QPIGS read timeout
Sun Jun 19 19:07:19 2022 INVERTER: QPIGS reply too short (14 bytes)
Sun Jun 19 19:07:19 2022 INVERTER: Current CRC: F8 54
Sun Jun 19 19:07:22 2022 INVERTER: QPIRI read timeout
Sun Jun 19 19:07:23 2022 INVERTER: QPIRI reply too short (0 bytes)
Sun Jun 19 19:07:23 2022 INVERTER: Current CRC: B4 DA
Sun Jun 19 19:07:26 2022 INVERTER: QPIWS read timeout
Sun Jun 19 19:07:27 2022 INVERTER: QPIWS reply too short (7 bytes)
Sun Jun 19 19:07:32 2022 INVERTER: Current CRC: 49 C1
Sun Jun 19 19:07:33 2022 INVERTER: QMOD reply size (5 bytes)
NAKssun 19 19:07:33 2022 INVERTER: QMOD: incorrect start/stop bytes. Buffer: (NAKs▒
uration options for the actual inverter polling process…
The device to read from…
Use: /dev/ttyS0 if you have a serial device,
/dev/ttyUSB0 if a USB<>Serial,
/dev/hidraw0 if you’re connecting via the USB port on the inverter.
device=/dev/ttyUSB0
How many times per hour is the program going to run…
This is used to calculate the PV & Load Watt Hours between runs…
If unsure, leave as default - it will run every minute…
(120 = every 30 seconds)…
run_interval=120
This allows you to modify the amperage in case the inverter is giving an incorrect
reading compared to measurement tools. Normally this will remain ‘1’
amperage_factor=1.0
This allows you to modify the wattage in case the inverter is giving an incorrect
I think I finally made it, I had a rs232-usb cable that I connected to the rj45-rs232 inverter cable, and for now the data is reaching well to HA.
I was reading (again) all this topic and found some useful information that led me to success:
sudo stty -F /dev/ttyUSB0 sane (to first clean all the settings)
sudo stty -F /dev/ttyUSB0 2400 raw -echo (without the first command this one did not work)
cat /dev/ttyUSB0 (to confirm that data is passing by the rs232 usb adapter)
@catalinbordan
In this post you mention that you had changed the “readme” file with your instructions, but looking at your github page it remains the same as the ned-kelly.
