Hello everyone,
Although I´m sure still an ESPhome amateur, I flashed dozens of (mostly nodeMCU) ESP32 and ESP8266 devices via ESPhome command line tool. Now I tried to set up my first battery powered device: a simple HC-SR501 PIR-motion-sensor connected to a DFR Firebeetle using deepsleep and a 10000 mAh Li-Ion-Battery-Pack:
This is the actually working yet simple yaml-code:
substitutions:
device_name: "th_og_bewegungsmelder"
friendly_name: "Treppenhaus OG Bewegungsmelder"
mqtt_prefix: "th_og_bewegungsmelder"
esphome:
friendly_name: "${friendly_name}"
platformio_options:
upload_speed: 921600
on_boot:
priority: 190
then:
- mqtt.publish:
topic: th_og_bewegungsmelder/binary_sensor/pir_sensor/state
payload: "ON"
on_shutdown:
priority: 590
then:
- mqtt.publish:
payload: "OFF"
esp32:
board: firebeetle32
framework:
type: arduino
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 0.0.0.0
gateway: 0.0.0.0
subnet: 0.0.0.0
reboot_timeout: 0s
ap:
ap_timeout: 24h
ssid: “${friendly_name}"
password: !secret ap_password
fast_connect: true
logger:
level: NONE
mqtt:
broker: 0.0.0.0
port: 1883
username: !secret mqtt_username
password: !secret mqtt_password
will_message:
topic: th_og_bewegungsmelder/status
payload: online
ota:
deep_sleep:
run_duration:
default: 30s
gpio_wakeup_reason: 30s
sleep_duration: 24h
wakeup_pin:
number: GPIO15
mode: INPUT_PULLUP
wakeup_pin_mode: KEEP_AWAKE
binary_sensor:
- platform: gpio
pin:
number: GPIO15
filters:
- delayed_off: 5s
Now, although it works and battery keeps it going now for over a month due to esp32´s deep-sleep functions there remain some questions:
It takes about 3-4s for the lights to turn on. Any idea how to get ESP32s or this boards boot process faster? Tune the yaml? Change the wiring or parts? Climbing the stairs to first floor takes about 6s: it makes no sense for the lights to turn on after more than half of the stairs have been climbed in the dark…
Firebeetle has the capability to charge the JST-connected li-ion-battery when the micro-USB is connected to an AC-plug which makes is fairly convenient to recharge without changing the battery itself. Now in my setup there is the PIR-sensor also connected to Firebeetles JST-battery-connector: will that be a problem during the charging? I did not try to charge it this way yet…
Last but not least: as Firebeetle comes with such built-in battery and charge-connectors: does anyone know if there is a kind of “fuel-gauge” (like this MAX17043) somehow integrated into this board? Acuatlly I could not find any information about it in the docs…
Any help is very appreciated!
Kay
