Kobito
(kobi)
December 14, 2021, 3:41pm
43
Thats weird i am from germany aswell I still get the Could not resolve host: mobile.proscenic.com.de
Will set up the "old"app then and try, although the app kicked me out before and said I should update to the new Proscenic App
SO I cant add the M7 PRO to the old app, I do the setup steps then I get into the device, see the map and everything else, but If I go back, it just says “enter new device” again.
any ideas how to fix this? will there be support for the new app soonish ? @andker
EDIT: Contacted the proscenic support, newer m7 Pro only work with the new app proscenic and not with the proscenic home app
guess i have to write my own stuff or wait for support for the new app :C :sadge:
GeoffAtHome
(Geoff At Home)
December 15, 2021, 7:52pm
44
I have thrown together a python script to generate the secrets.yaml
file. This is because when you login from the mobile app the token changes.
import requests
import hashlib
import json
HOST = "mobile.proscenic.com.de"
def writeToFile(userName, token, serialNumber):
f = open("secrets.yaml", "w")
f.write("proscenic_username: " + userName + "\n")
f.write("proscenic_token: " + token + "\n")
f.write("proscenic_serial: " + serialNumber + "\n")
f.close()
def getToken(userName, password):
headers = {
'os': 'i',
'Content-Type': 'application/json',
'c': '338',
'lan': 'en',
'Host': HOST + ":443",
'User-Agent': 'ProscenicHome/1.7.8 (iPhone; iOS 14.2.1; Scale/3.00)',
'v': '1.7.8',
data = {
"state":"\u6B27\u6D32",
"countryCode":"49",
"appVer":"1.7.8",
"type":"2",
"os":"IOS",
"password":hashlib.md5(password.encode('utf-8')).hexdigest(),
"registrationId":"13165ffa4eb156ac484",
"language":"EN",
"username":userName,
"pwd": password
dataJSON = json.dumps(data)
response = requests.post("https://" + HOST + "/user/login", headers=headers, data=dataJSON.encode('utf-8'), verify=False)
if response.status_code == 200:
content = response.json()
data = content['data']
if data['equipcount'] == 0:
print("Equipment count is zero. Username or password maybe wrong")
token = data['token']
return token
return "Unable to get token"
def getSerialNumber(userName):
data = {
"username": userName
response = requests.post("https://" + HOST +"/user/getEquips/" + userName, data=dataJSON.encode('utf-8'))
if data['totalElements'] == 0:
print("Total Elements is zero. Username maybe wrong")
serialNumber = data['content'][0]['sn']
return serialNumber
return "Unable to get serial number"
def main():
LOGINUSER="Your Username"
PASSWORD="Your Password"
# LOGINUSER=input("Username: ")
# PASSWORD=input("Password: ")
token = getToken(LOGINUSER, PASSWORD)
serialNumber = getSerialNumber(LOGINUSER)
writeToFile(LOGINUSER, token, serialNumber)
main()
print('done')
Uncomment the two input lines if you want to type your username and password in from the command line.
Kobito
(kobi)
December 15, 2021, 10:41pm
45
thx will try it tomorrow, but dont expect it to work cause i have to use the new app :C
still nice if you want to log into the app from time to time
gomba
(Carlo)
December 20, 2021, 7:02pm
46
@Kobito If it helps, the command I used to check what server is being used by the app is:
adb logcat | grep mobile.proscenic
That will display all the log messages from the phone and filter them for the Proscenic URL that is being used. This of course requires ADB to be installed: SDK Platform Tools release notes | Android Developers
Kobito
(kobi)
December 21, 2021, 9:48pm
47
ty alot, but because i am not using the proscenic home but the proscenic app, cause i cant add my m7 pro to the “old” app, there is no need to check the server
K3kl10
(K3kl10)
May 6, 2022, 2:58pm
48
hello.
I understood the manipulation you are talking about with the scripts. I created the folder as well as the script file in .py but despite the update, when I call the service that runs the script the secret file does not change. I have entered the username and password correctly. Can you do a little tutorial to integrate it? thank you.
Secret for me only changed when I logged in from a different location. I. E. My phone.
At the moment this is no longer working for me and I don’t know why.
c.marteddu
(C Marteddu)
January 28, 2023, 1:44am
50
Sorry, I can’t integrate my M7 PRO, on a MacBook terminal the first answer is this:
dquote>
Can someone help me?
A thousand thanks
c.marteddu
(C Marteddu)
February 21, 2023, 3:50pm
51
[email protected]
PASSWORD=very-secure
curl -v -k -X POST -H “os: i” -H “Content-Type: application/json” -H “c: 338” -H “lan: en” -H “Host: mobile.proscenic.com.de:443 ” -H “User-Agent: ProscenicHome/1.7.8 (iPhone; iOS 14.2.1; Scale/3.00)” -H “v: 1.7.8” -d “{“state”:“欧洲”,“countryCode”:“49”,“appVer”:“1.7.8”,“type”:“2”,“os”:“IOS”,“password”:”$(echo -n $PASSWORD | md5sum)",“registrationId”:“13165ffa4eb156ac484”,“language”:“EN”,“username”:"$LOGINUSER",“pwd”:"$PASSWORD"}" “https://mobile.proscenic.com.de/user/login ”
[email protected]
curl “https://mobile.proscenic.com.de/user/getEquips/$LOGINUSER ” -d “username=$LOGINUSER”
c.marteddu
(C Marteddu)
52
copie e incolla i due comandi così
