I am trying to understand the Proximity Integration, so if I have a single zone create via settings/areas/zone and this zone is about 100 meters wide. I then I create my proximity config around this zone and add a single tracker and set the tolerance to 10 meters.
Firstly; what does the tolerance mean? does is mean if the tracker moves inside my 100 meter zone by less than 10 meters then no event will be triggered? if so, unsure why you would want an event on movement within a zone.
Secondly; when performing an automation using this zone and the state is equal to 1 (m) does that mean the tracker is within 1 (m) of the edge of the zone or within 1 (m) to the center of the zone?
