just a heads-up for those who are running proxmox and would like to upgrade to the latest version. Do not do it if you are running frigate. Why? at this moment google pycoral did not support Python 3.11. I have to learn the hard way and currently downgrade my proxmox.
Anyone who knows how to solve it please share your way. Thanks
Well after proxmox upgrade to version 8. My frigate fails to call upon the pass-through and receives an error. LXC somehow fail. So any help will be appreciated
P.S. I downgrade proxmox back to ver 7 and it work without any problem
I will try it on my temporary machine and will let u know. As of now, HA is the primary system at my home. If it dead the entire day Wifey will 100% get pissed hahahahaha…
Thanks very much…i did try removing the sonoff then adding it back in…strangely the original dongle (a Sonoff -E model) comes up in the usb passthrough but isnt identified whereas the Sonoff oplus ( i get mixed up with the model numbers) can be read in the passthrough…ie proxmox sees it…just an observation…
My current theory is to use the “plus” dongle as i managed to get the firmware up to date on that (2023 date on it) and then maybe try to reconfigure it (almost start from scratch) - to see if i can get it working…
Going to try updating the firmware on the older one tonight…for some inexplicable reason i cant ever get them into bootloader mode and have to do it using Python.
The USB device is detected as soon as it’s plugged in. The coral driver is stored internally for the USB based coral. All the plugins necessary are inside the frigate container already.
Bus 004 Device 002: ID 1a6e:089a Global Unichip Corp.
And not related to Google.
Also, i’m running Ubuntu 22.04 in the container. But probably i should recheck my config, since you’re saying that should be trivial.
