This tells me it’s running the startup script for HA Add-ons. Not the one for docker standalone.
I can’t make it work (and it used to)…
Did something in your volume setup or run.sh script change?
P.s. If you make an issue on GitHub please fill out the whole template. Logs like these make it 1.000.000 times easier to figure out what is going wrong.
not sure about the first comment re supervisor, the startup script has been the same the whole time (as per your docs) and it is working now
re issue - funnily enough, I tried a moment ago and it seems to be working now, i.e. shows activity on both accounts (btw. I wonder what happens if two users play at the same time, will test and let you know). I will close the issue for now (btw. I know logs are helpful, but opened issue from my mobile…)
the only errors I see in the log now are:
2023-04-17T05:57:44.154Z @ha:ps5:error config could not be read from 'undefined'
and:
2023-04-17T06:00:15.728Z @ha:ps5:error SyntaxError: Unexpected end of JSON input
at JSON.parse (<anonymous>)
at /app/server/dist/redux/sagas/check-devices-state.js:78:38
at step (/app/server/dist/redux/sagas/check-devices-state.js:35:23)
at Object.next (/app/server/dist/redux/sagas/check-devices-state.js:16:53)
at next (/app/node_modules/@redux-saga/core/dist/redux-saga-core.dev.cjs.js:1161:27)
at currCb (/app/node_modules/@redux-saga/core/dist/redux-saga-core.dev.cjs.js:1255:7)
at runSelectEffect (/app/node_modules/@redux-saga/core/dist/redux-saga-core.dev.cjs.js:735:5)
at runEffect (/app/node_modules/@redux-saga/core/dist/redux-saga-core.dev.cjs.js:1208:7)
at digestEffect (/app/node_modules/@redux-saga/core/dist/redux-saga-core.dev.cjs.js:1275:5)
at next (/app/node_modules/@redux-saga/core/dist/redux-saga-core.dev.cjs.js:1165:9)
Hi, thanks for the amazing plugin!
Everything is working fine, but the only problem I have is that the npsso token (for retreiving game data) expires after I put the PS5 in rest mode… and when I start the PS again the plugin tells me the token is not valid… I than retrive a new token and it works again till I finish gaming and put the PS5 in rest mode again.
After couple months (i set up from February) i think stop working the game name and icon. While play a game it says “open” and not game icon and icon controller
I need help! I’m lost on how to get the NPSSO to a token… i was able to get my ssocookie by don’t know how to run does commands that the document talk about to get the token from the ssocookie! any help will be appreciated…
