im having a issue starting the add on. ive tried both addons and inputed info into config.
Preformatted text24-02-26 00:29:38 WARNING (MainThread) [supervisor.addons.addon] df2164f9_ps5_mqtt_edge is already running!
24-02-26 00:29:47 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon PS5 MQTT - Edge to start, took more than 120 seconds
24-02-26 00:31:38 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon PS5 MQTT - Edge to start, took more than 120 seconds
24-02-26 00:32:34 WARNING (MainThread) [supervisor.addons.addon] df2164f9_ps5_mqtt_edge is already running!
24-02-26 00:33:24 WARNING (MainThread) [supervisor.addons.addon] df2164f9_ps5_mqtt_edge is already running!
24-02-26 00:34:34 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon PS5 MQTT - Edge to start, took more than 120 seconds
24-02-26 00:35:24 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon PS5 MQTT - Edge to start, took more than 120 secondsPreformatted text
logs from the add on are:
Preformatted textStarting PS5-MQTTā¦
2024-02-26T00:27:48.267Z @ha:ps5:webserver Server listening on PORT: 65310
2024-02-26T00:27:48.296Z @ha:ps5:mqtt MQTT Message received ps5-mqtt/78C881AA9A3F
2024-02-26T00:27:51.289Z @ha:ps5:mqtt MQTT Message received ps5-mqtt/78C881AA9A3FPreformatted text
Did anybody change activated Keypass for PSN? Is the Addon still working as before?
Actually I donāt see a direct relationship, but wanna make sure there is no side effect before deactivating PW.
My experience as a user of the add-on:
Works fine (once i jumped through all the hoops of set-up), until I login into playstation.com from my webbrowser and playstation.com again asks me for my login (from the same computer and webbrowser that I just finished my setup for PS5-MQTT just a couple of minutes ago), then PS5-MQTT stops working again.
I assume with my new login at playstation.com, the NPSSO key that PS5-MQTT uses gets invalidaded by the website login.
So I refrain from loging into playstation.com, and everything works fine from now on.
Also (which I only realized earlier): If you change the configuration of PS5-MQTT (for example pasting a new NPSSO key into the PS5-MQTT configuration), you have to restart the PS5-MQTT Add-on, not Home Assistant.
DāOh, took me a long time figuring that out.
Of course, PS5-MQTT was just the first add-on I discovered this.
At around the same time it dawned on me (ie. I read it somewhere and understood it) that add-ons are not HA āpluginsā, they are separate programs that run in their own docker (docker-like?) container and communicate with HA. With this understanding a couple of things that baffled me before suddenly makes sense (among those that you need to restart the add-on, as restarting HA does not do anything to the programs running in their own container).
Recently, the PS5-MQTT stopped working. Iām not sure if itās because Sony implemented the Passkey or because I added a second account to the Docker stack.
In any case, this is the stack Iām running (Iāve hidden the security details) and Iām also sending the Logs
version: '3'
services:
ps5-mqtt:
container_name: PS5-MQTT # choose whatever name you like
image: ghcr.io/funkeyflo/ps5-mqtt/amd64:latest # you can also use a specific version
entrypoint: /config/run.sh # the file that will be executed at startup
volumes: # we will use this volume to get our custom startup script into the container
- /home/USER/ps5mqtt/config:/config
network_mode: host # changing/omiting this option WILL BREAK the app.
restart: "always"
environment:
- MQTT_HOST=xxx.xxx.xxx.xxx # (ip)address of your mqtt broker
- MQTT_PORT=1883 # port of your mqtt broker
- MQTT_USERNAME=username # username used for connecting to your mqtt broker
- MQTT_PASSWORD=Password # password used for connecting to your mqtt broker
- DEVICE_CHECK_INTERVAL=5000
- DEVICE_DISCOVERY_INTERVAL=60000
- ACCOUNT_CHECK_INTERVAL=5000
- PSN_ACCOUNTS=[{"username":"Account Mail", "npsso":"NPSSO of user 1"}, {"username":"Account Mail", "npsso":"NPSSO of user 2"}
- INCLUDE_PS4_DEVICES=false
- FRONTEND_PORT=8645
- CREDENTIAL_STORAGE_PATH=/config/credentials.json
- DEBUG=@ha:ps5:*
LOGS
Starting PS5-MQTT...
2024-03-20T10:30:08.826Z @ha:ps5:error config could not be read from 'undefined'
undefined:1
SyntaxError: Unexpected end of JSON input
at JSON.parse (<anonymous>)
at getEnvConfig (/app/server/dist/config.js:78:43)
at getAppConfig (/app/server/dist/config.js:40:22)
at Object.<anonymous> (/app/server/dist/index.js:92:43)
at Module._compile (node:internal/modules/cjs/loader:1198:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1252:10)
at Module.load (node:internal/modules/cjs/loader:1076:32)
at Function.Module._load (node:internal/modules/cjs/loader:911:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
at node:internal/main/run_main_module:22:47
Iād love to know if there is any trick you used to make this work - I am a complete docker and unraid noob and trying to move across from my old HA system
Iāve tried to set up the docker in a few different ways before coming across your template (which is much more elegant than what I have been doing!) but whatever I do it always comes back to this error -
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: exec: ā/config/run.shā: permission denied: unknown.
Iāve tried different owners/permissions on run.sh but nothing seems to change⦠Did you get anything like this at all?
Installed in Supervised HA.
I couldnāt get the web-ui to load until I opened the port that the log announced the add-on is listening on (looks like everyone has their own unique port?), and then I couldnāt get it to recognize the PS5 until I completely disabled UFW. I tried opening 8645, 64977 (the port reported in the log), and 977 and 9302 (both reported by the web-ui when it discovered the PS5 while UFW was disabled). If Iām understanding this GitHub issue correctly, does this mean that this add-on will only work if I disable my firewall on the host machine? I have no VLANs in my network, if that matters.
Turns out I only needed to have the firewall disabled to initially discover and set up the connection and authentication. Once I did that, I tried re-enabling the firewall and the I can still control the PS5. Weird.
Does the PS5 need an Ethernet connection in order for the Power switch to work? I have it currently connected over WiFi but the switch does not seem to work at all. The activity does not have any issues.
Thatās right. I know that, it doesnāt work on rest mode either. Thatās why I was asking if thereās any additional configuration that has to be done on my side.
