PSA: Turn on/off all lights in Home Assistant 0.104+ (group.all_* changes)
Thoughts on conditions?
condition: state
entity_id: group.all_lights
state: 'off'
Becomes what?
I use that one in combination with a time condition to work out when everyone who is home has gone to bed. I’ve had to resort to listing all the lights for now but it’s a bit messy.
A hot mess.
condition: template
value_template: >
  {{ states.light | count == states.light | selectattr('state','eq','off') | list | count }}
It’s a truck load prettier than what I typed out earlier! Cheers :sunglasses:
Yeah, nobody turns off all_lights anyways, right? :crazy_face:
hello, does anyone know how to replace the group.all_devices as trigger and condition in an automation?
  - entity_id: group.all_devices
    platform: state
    to: not_home
  - condition: state
    state: home
The trigger is tricky.
Probably the easiest without listing all the devices:
- platform: event
  event_type: state_changed
- condition: template
  value_template: "{{ trigger.event.entity_id.split('.')[0] == 'device_tracker' }}"
The condition is also tricky, but easier
  value_template: "{{ states.device_tracker | count == states.device_tracker | selectattr('state','eq','home') | list | count }}"
thanks a lot,ill try it and change all them
the problem is that with group.all_devices when one of the device_tracker entities has the value “home”, the status of the group also changes to “home”, the condition does not work, the trigger has not yet been able to test it.
thanks
Ah ok, use this
  value_template: "{{ states.device_tracker | selectattr('state','eq','home') | list | count > 0 }}"
Hey Google… turn off all the lights…
TOP,thanks a lot again,thats its working,
I just need to try the trigger
Maybe is a silly question, but if I create a group with all device_tracker I have, wouldn’t it work just like the old group.all_devices?
EDIT: thats working,i think is the best fix for me
:grinning:
I though I understood how piping worked in Home Assistant but the use of the piping here really confuses me. Anybody cares to explain to me what’s going on?
The way I see it, states[domain] returns a list of states the entities of type domains are and piping that to count will result in the number of devices returned. So what piping that number to an equality test with the list again do?
Bit disappointed with this update.
How can I now easily check if all door are locked. Now i need to maintain the group myself. A pitty they did not foresee an option to make the groups available again.
I have a Node-red flow to turn off ALL lights except a few (using a function node), guess I know have to iterate over all the entities …
No you don’t. I posted a solution here:
Change domain to ‘lock’ and state to ‘locked’.
  value_template: >
    {% set domain = 'lock' %}
    {% set state = 'locked' %}
    {{ states[domain] | count == states[domain] | selectattr('state','eq', state) | list | count }}
Again, no you don’t. Node red calls a service. Instead of using entity_id: ‘group.all_lights’, use entity_id: ‘all’.
I get that, but previously I iterated over the entities in the group. Using all only works when trying to turn off the lights, not for getting the list of entities.
Luckily I’ve put all that code in a subflow, so it’s a change on 1 place, but still. This change kinda sucks.
dude, i posted that solution as well…
Use this as a list of entity_id’s to return to entity_id’s
{{ states.switch | map(attribute='entity_id') | list | join(', ') }}
Use this to find all items in a domain
{{ states.switch | map(attribute='entity_id') | list }}
EDIT: In the words of southpark “Rabble rabble rabble rabble”
What about some tiny python_script to get your group.all_* back?
automation:
  - alias: HA Start automation
      platform: homeassistant
      event: start
      - service: python_script.create_all_group
          domain: light
          group: all_lights
python_scripts/create_all_group.py
domain = data.get('domain')
group = data.get('group')
service_data = {"object_id": group, "entities": hass.states.entity_ids(domain)}
hass.services.call("group", "set", service_data, False)
I have no clue if this is safe, but it works for me. :sunglasses: It is!
EDIT: optimized create_all_group.py
Nice list @petro, thanks for compiling.
adding my bit: just discovered we can also expand the domain, as an alternative:
count
{% set lights = expand(states.light)
|selectattr('state','eq','off')|list|count %}
{{lights}}
list:
|selectattr('state','eq','off')|map(attribute='name')|list %}
{{lights}}
