I have recently moved to home assistant and I am currently trying to intergrate my smartthings devices into home assistant.
I have followed the smartthings intergration in terms of creating a Nabu casa account and logging onto Smartthings IDE to get a api token.
After a few restarts I finally ended up with this card.
It would seem that the only data I can see from my fridge freezer is the door state which works both on the fridge door and the freezer door.
I can see push notifications in the home assistant logs for the doors and can see the temperatures updated within the data area of the fridgefreezer device page within Smartthings IDE but I cannot figure out how to get these values into home assistant.
I have tried to follow some of the other posts within this forum regarding this issue using cURL commands which I canât seem to get to work and adding rest sensors to my Config Yaml but the unknown status always seems to remain the same.
I have changed the Device Network ID to something unique and have changed the type from placeholder to Samsung OCF Refrigerator but again no change.
I am new to the world of home assistant, cURL commands and rest sensors but have managed to intergrate shelly bulbs, energy monitor and pulled in PC data using MQTT so it maybe that I am missing something when trying to set up pulling in some data from smartthings.
So I managed to get this working with the following config in my configuration.YAML file. However this has now stopped working due to the smartthings api being changed. I can get to a JSON page using the web address âhttps://api.smartthings.com/v1/devices/----/statusâ but I canât understand how to get this working again. I have looked at the restful sensor integration and have tried changing some of the config but nothing seems to work.
Would really appreciate some help with this or some info on why it doesnât work any longer.
Bump this for help. I think this is still an outstanding issue. Has anyone found any resolution?
I have installed the SmartThings integration and performed the necessary steps to access the device in HA. However I see the same as above, there is only listing for one âTemp measurementâ and âtemp set pointâ but the entities have an âunknownâ state. However, all the other entities have valid states and update regularly.
Does the ***** by resource stand in for the refrigerator token? And What needs to be put in for the ***** after Bearer? Sorry if this seems like a basic question.
I havenât looked at this in forever because it had stopped working but i looked because of this post and it appears to be working. I have no idea when it started working but I moved to Home Assistant Yellow 4-5 months ago and that wouldâve been the last time I touched the integration and acknowledged it as not working.
