Yes. the pir sensor will send Android a message.
Clear cashe, or clear data, or both?
Thanks for hanging in there with me.
That’s not what I meant, I meant to try: Actionable Notifications | Home Assistant Companion Docs and see if you can see the Actions show up in the notification. If that does not work then do: Troubleshooting | Home Assistant Companion Docs and try again with the image.
Both options. No luck…
I believe the fundamental problem is here. Why doesn’t this send the image to my Android device? This is the litmus test for all? Developer tools>services>call service no?
Text can be sent, images no. So puzzling? Nothing it the logs all, no errors registered at all.
I deleted the app and reinstalled it? Restarted the server, logged in, logged out, logged in.
Can take a picture, store it, but not send it to my app. How does it work for everyone else. I must be missing something basic in the initial configuration or set-up…
I’d really appreciate you insight.
Many Thanks.
You are not sending the correct data for the service call. Look at the format and follow the format
message: TEXT
image: URL
message
is a required parameter, and the URL is still not correct test it in a browser to make its valid and publicly accessible.
If you still have issues I suggest you read the companion docs that I linked to, they will show you what is expected.
Hy,
is it possible to template the image url like this:
title: "Müllabfuhr"
message: >
{% if is_state_attr("sensor.ics_1", "remaining",1) %} {{states.sensor.ics_1.attributes.friendly_name}} wird morgen abgeholt. - {{ now().strftime('%I:%M %p') }}{% endif %}
{% if is_state_attr("sensor.ics_2", "remaining",1) %} {{states.sensor.ics_2.attributes.friendly_name}} wird morgen abgeholt. - {{ now().strftime('%I:%M %p') }}{% endif %}
{% if is_state_attr("sensor.ics_3", "remaining",1) %} {{states.sensor.ics_3.attributes.friendly_name}} wird morgen abgeholt. - {{ now().strftime('%I:%M %p') }}{% endif %}
data: >
image: >
{% if is_state_attr("sensor.ics_1", "remaining",1) %} !secret trash_black {% endif %}
{% if is_state_attr("sensor.ics_2", "remaining",1) %} !secret trash_yellow {% endif %}
{% if is_state_attr("sensor.ics_3", "remaining",1) %} !secret trash_red {% endif %}
I don’t get it how to …
You are 100% correct. The issue is that the file is not public. I receive a 404 error when trying to access the photo from a browser.
I’m running Hassio via Ubuntu on VirtualBox. Any idea how to make the www folder public? I’ve dug around and don’t have a solution yet. The folder permissions are fine.
Oh, and yes, actionable notifications work just fine.
Many thanks.
I had another crack at it by calling on some random publicly available image from google.
message: testing 1-2-3
image: https://www.google.com/imgres?imgurl=https%3A%2F%2Fimage.pbs.org%2Fvideo-assets%2FmknIjcl-asset-mezzanine-16x9-kknCeMo.jpg%3Fcrop%3D384x215%26%3Fformat%3Djpg&imgrefurl=https%3A%2F%2Fvideo.mpt.tv%2Fshow%2Fmotor-week%2F&tbnid=l7SuP7tPxUdGgM&vet=12ahUKEwiy_7H4x-DoAhWN1-AKHRGlBn8QMygUegQIARBB..i&docid=AHuVgd8JKHBjgM&w=384&h=215&q=car%20image%20thumbnail&ved=2ahUKEwiy_7H4x-DoAhWN1-AKHRGlBn8QMygUegQIARBB
Still the same error. websocket_api.http.connection.
Does this Call Service work for you? It should be a blue bi-turbo Merc. Works right?
I suspect it has something to do with my set-up. Digging around today I discovered that if your profile is running on the backend and not the front end there is some kind of api issue. However frontend is supposed to be enabled by default…In my profile the theme is backend-selected.
Any insight would be appreciated.
Many Thanks
This still not a valid URL. Pick a real image URL like: https://upload.wikimedia.org/wikipedia/commons/3/3a/Cat03.jpg
your indentation of image
looks off and make sure you are using data_template
before message
and topic
data_template:
message: MESSAGE
topic: TOPIC
image: URL
Still…nothing. same Error.
Logger: homeassistant.components.websocket_api.http.connection.1234567890
Source: core.py:1210
Integration: websocket_api
you keep forgetting to follow all the steps lol
see the format I gave you 21 hours ago?
Try this service data
message: test
image: https://upload.wikimedia.org/wikipedia/commons/3/3a/Cat03.jpg
How, Why, What…How? My poor brain.
Thanks for hanging in there with me! Now just to figure out why the doorbell.jpg file in my www folder is not public.
Many Thanks!
Check the third paragraph here, it explains in detail what is expected with a few different options to try: https://companion.home-assistant.io/docs/notifications/notification-attachments
/api/camera_proxy/camera.name finally worked.
unbelievable. thanks for you help!
HI is it possible to use a camera entity to show live video in a notification on android as you can do on iOS
like below
content-type: jpg
hide-thumbnail: false
entity_id: camera.foscam_camera
push:
badge: 0
category: camera
message: Someone is at the front door
This shows live video in a notification for iOS
HI trying to sue the below url to see camera feed but get an unauthorised error
http://192.168.#.#:8123/api/camera_proxy_stream/camera.foscam_camera?token=long live token
Can anyone assist
Thanks but that is what I am trying to use
With no luck
Correct but your previous post was not the same as this. Make sure that your base_url
is defined or if you use nabu casa turn on remote
Thanks, sorry for the possible dumb question.
what do you mean by base_url defined. I am not using Nabu Casa
thanks
