Since I have upgraded to 0.52 I get an pushbullet error in log:
2017-08-28 13:14:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/pushbullet.py", line 130, in send_message
self.pbtargets[ttype][tname].push_note(title, message)
File "/usr/lib/python3.6/site-packages/pushbullet/device.py", line 22, in push_note
return self._push(data)
File "/usr/lib/python3.6/site-packages/pushbullet/device.py", line 41, in _push
return self._account._push(data)
File "/usr/lib/python3.6/site-packages/pushbullet/pushbullet.py", line 309, in _push
raise PushError(r.text)
pushbullet.errors.PushError: {"error":{"code":"pushbullet_pro_required","type":"invalid_request","message":"Pushbullet Pro is required to make this call.","cat":"🙀"},"error_code":"pushbullet_pro_required"}
Someone else get this error. Worked for me until 0.51.2. I made no configuration changes.
2017-08-28 21:03:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1025, in _event_to_service_call
yield from service_handler.func(service_call)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/notify/__init__.py", line 138, in async_notify_message
yield from notify_service.async_send_message(**kwargs)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/notify/pushbullet.py", line 92, in send_message
self._push_data(filepath, message, title, self.pushbullet, url)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/notify/pushbullet.py", line 142, in _push_data
pusher.push_link(title, url, body=message, email=tname)
AttributeError: 'str' object has no attribute 'push_link'
@Danielhiversen 0.52.1 did not fix my issue.
Sorry for delay. I’m on hassio, hence update is available later. Same error message:
2017-08-29 09:45:20 ERROR (SyncWorker_0) [homeassistant.components.notify.pushbullet] Notify failed: {"error":{"code":"pushbullet_pro_required","type":"invalid_request","message":"Pushbullet Pro is required to make this call.","cat":"🙀"},"error_code":"pushbullet_pro_required"}
I did browsing the code for pushbullet notifier on github.com. Could it have something to do with the fact, that I’m not using an url or a file? Look at the error message -> invalid_request.
I am having problems here as well. It was working fine before I upgrade to 0.52.1.
Below is my log:
2017-08-30 21:01:32 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.6/asyncio/tasks.py", line 181, in _step
File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1025, in _event_to_service_call
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 138, in async_notify_message
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/pushbullet.py", line 92, in send_message
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/pushbullet.py", line 142, in _push_data
AttributeError: 'NoneType' object has no attribute 'push_link'
and here is my automation:
- id: garage_notify
alias: If Garage is open for 5 minutes notify
platform: state
entity_id: binary_sensor.garage_door
to: 'on'
for:
minutes: 5
service: notify.douglas
message: "Garage has been open for 5 minutes"
title: "Home Assistant"
Any ideas on how to fix it? I am using Hass.io on Pi.
PS.: I used a shell script to test my pushbullet account and it is working fine.
I haven’t tried the latest fix, but with 0.52.1, if I use “channel/XXXX” as the target, I get:
2017-08-30 10:07:07 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 182, in _step
File "/usr/src/app/homeassistant/core.py", line 1025, in _event_to_service_call
File "/usr/src/app/homeassistant/components/notify/__init__.py", line 138, in async_notify_message
File "/usr/local/lib/python3.6/asyncio/futures.py", line 332, in __iter__
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/src/app/homeassistant/components/notify/pushbullet.py", line 128, in send_message
self.pbtargets[ttype][tname])
File "/usr/src/app/homeassistant/components/notify/pushbullet.py", line 154, in _push_data
pusher.push_note(title, message, email=tname)
TypeError: push_note() got an unexpected keyword argument 'email'
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/core.py", line 1025, in _event_to_service_call
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/__init__.py", line 138, in async_notify_message
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/pushbullet.py", line 92, in send_message
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/pushbullet.py", line 142, in _push_data
