I went to this thread because i’m having your same issue, can you explain what procedure i have to follow to install home assistant on synology ds215j?
yesterday i followed this guide https://www.home-assistant.io/docs/installation/synology/ without success, the process wont start.
after i’ve found this guide Home Assistant won't start on Synology DS115j NAS that tell’s to downgrade pip with sudo python3 -m pip install pip==9.0.1
process started but no web page access.
after tryed this modification https://www.home-assistant.io/docs/ecosystem/synology/ but still no web page access.
what i have to do now? i uninstall everything and use the package in this page?
http://spk.chickenandporn.com/?arch=armada375#
i have to mantain the user and the folder or start from zero?
thank you
