I’m on HassOS and I followed this guide , I’m having an issue with a command line sensor:
- platform: command_line
command: "python3 /config/custom_components/pfSense/pfSense_get_system_stats.py <host> <apikey> <apisecret>"
<host> is the ip of my pfSense firewall, <apikey> is the apikey etc.
When I run the command from ssh/terminal in Home Assistant it works fine, but the same command run from the sensor fails:
Logger: homeassistant.components.command_line
Source: components/command_line/__init__.py:41
Integration: command_line (documentation, issues)
First occurred: 22:49:15 (4 occurrences)
Last logged: 23:04:17
Command failed: python3 /config/custom_components/pfSense/pfSense_get_system_stats.py <host> <apikey> <apisecret>
Anyone know why? Or what I should be doing differently?
gremblin
(Eric)
November 10, 2020, 3:15am
2
what does your config look like for the sensor?
Hi! Thanks for coming back to me, the config of the sensor is:
I followed the instructions in @bthoven ’s comment as they were for hassio/HassOS
gremblin
(Eric)
November 10, 2020, 2:31pm
4
This is mine. I store my .py files in the python_scripts directory, but I don’t think that matters. I wonder if it has something to do with you not doing anything with the data after calling the command. I use the command_line sensor to grab the CPU temp, then the script also creates a file for the other file sensors.
#pfSense Stats Capture#
command: "python3 /config/python_scripts/pffa_get_system_stats.py <host> <api_key> <api_secret>"
value_template: '{{ value_json["data"]["stats"]["temp"] }}'
unit_of_measurement : 'C'
- platform: file
file_path: /config/python_scripts/pfSense_stats.json
value_template: '{{ value_json["data"]["stats"]["uptime"] }}'
- platform: file
value_template: '{{ value_json["data"]["stats"]["mem"] }}'
unit_of_measurement : '%'
- platform: file
# value_template: '{{ ( ( ((value_json["data"]["stats"]["cpu"].split("|")[0] | float) / (value_json["data"]["stats"]["cpu"].split("|")[1] | float)) - 1.0 ) * 100.0 ) | round(1) }}'
value_template: '{{ ((value_json["data"]["stats"]["load_average"][0] | float) * 100.0 / 4.0 ) | round(0) }}'
- platform: file
value_template: '{{ value_json["data"]["stats"]["mbufpercent"] }}'
That was it, as soon as I added the code to grab the CPU temperature after the command it worked. I now feel like an idiot! But I’m glad that it’s working!
Thanks for your suggestion
gremblin
(Eric)
November 12, 2020, 3:12pm
6
Glad it’s working Don’t worry we all feel like idiots at times
