*** EDIT *** Everythings working now. All code in this first post has been changed to correct some quirks. Full installation instructions can be found some posts below:
— Original post —
This is my first thread here and I’m really learning HA these days. So any help is highly appreciated. And please, english is not my native language - so please don’t laugh ![]()
With a mix of several forum entries here I got my QCell Q.Home mostly working. But there are some questions regarding the energy dashboard left:
On the energy dashboard certain values are negative. It seems that these values are turned upside down. If you look at my code below I create positive values as advised for these values. Where do the negative values on the energy dashboard come from?
The graph shows all dots traveling (and values for all directions) even if the values for some directions are ‘0’. What am I doing wrong?
Many thanks in advance.
My collected solution:
How to call the QCells Cloud (max. 5 min intervall):
https://qhome-ess-g3.q-cells.eu/proxyApp/proxy/api/getRealtimeInfo.do?tokenId=xxxxxxxx&sn=yyyyyyyy
The result of this call:
{"success":true,"exception":"Query success!","result":{"inverterSN":"zzzzzzzz","sn":"yyyyyyyy","acpower":641.0,"yieldtoday":4.7,"yieldtotal":141.9,"feedinpower":0.0,"feedinenergy":44.98,"consumeenergy":17.15,"feedinpowerM2":0.0,"soc":24.0,"peps1":0.0,"peps2":0.0,"peps3":0.0,"inverterType":"14","inverterStatus":"102","uploadTime":"2022-11-03 09:55:19","batPower":568.0,"powerdc1":639.0,"powerdc2":636.0,"powerdc3":null,"powerdc4":null,"batStatus":"0"}}
secrets.yaml:
#xxxxxxxx=Token
#yyyyyyyy=Wifi serial
qcells_cloud: https://qhome-ess-g3.q-cells.eu/proxyApp/proxy/api/getRealtimeInfo.do?tokenId=xxxxxxxx&sn=yyyyyyyy
configuration.yaml:
- platform: rest
resource: !secret qcells_cloud
method: GET
scan_interval: 300
timeout: 60
value_template: 'OK'
json_attributes_path: "$.result"
json_attributes:
- sn
- acpower
- yieldtoday
- yieldtotal
- feedinpower
- feedinenergy
- consumeenergy
- feedinpowerM2
- soc
- peps1
- peps2
- peps3
- inverterType
- inverterStatus
- uploadTime
- batPower
- powerdc1
- powerdc2
- powerdc3
- powerdc4
- batStatus
sensors:
qcells_cloud_sn:
friendly_name: "QCells Unique identifier of communication module"
value_template: "{{ state_attr('sensor.qcells_cloud', 'sn') }}"
qcells_cloud_acpower:
friendly_name: "QCells Inverter AC power total"
value_template: "{{ state_attr('sensor.qcells_cloud', 'acpower') }}"
unit_of_measurement: "W"
device_class: power
qcells_cloud_yieldtoday:
friendly_name: "QCells Inverter AC energy out daily"
value_template: "{{ state_attr('sensor.qcells_cloud', 'yieldtoday') }}"
unit_of_measurement: "kWh"
device_class: energy
qcells_cloud_yieldtotal:
friendly_name: "QCells Inverter AC energy out total"
value_template: "{{ state_attr('sensor.qcells_cloud', 'yieldtotal') }}"
qcells_cloud_feedinpower:
friendly_name: "QCells Grid power total"
value_template: "{{ state_attr('sensor.qcells_cloud', 'feedinpower') }}"
device_class: power
qcells_cloud_feedinenergy:
friendly_name: "QCells Grid energy to Grid total"
value_template: "{{ state_attr('sensor.qcells_cloud', 'feedinenergy') }}"
qcells_cloud_consumeenergy:
friendly_name: "QCells Grid energy from Grid total "
value_template: "{{ state_attr('sensor.qcells_cloud', 'consumeenergy') }}"
qcells_cloud_feedinpowerm2:
friendly_name: "QCells Inverter Meter2 AC power total"
value_template: "{{ state_attr('sensor.qcells_cloud', 'feedinpowerM2') }}"
device_class: power
qcells_cloud_soc:
friendly_name: "QCells BMS energy SOC"
value_template: "{{ state_attr('sensor.qcells_cloud', 'soc') }}"
unit_of_measurement: "%"
qcells_cloud_peps1:
friendly_name: "QCells Inverter AC EPS power 1"
value_template: "{{ state_attr('sensor.qcells_cloud', 'peps1') }}"
device_class: power
qcells_cloud_peps2:
friendly_name: "QCells Inverter AC EPS power 2"
value_template: "{{ state_attr('sensor.qcells_cloud', 'peps2') }}"
device_class: power
qcells_cloud_peps3:
friendly_name: "QCells Inverter AC EPS power 3"
value_template: "{{ state_attr('sensor.qcells_cloud', 'peps3') }}"
device_class: power
qcells_cloud_invertertype:
friendly_name: "QCells Inverter Type"
value_template: >-
{% if state_attr('sensor.qcells_cloud', 'inverterType') == "1" %}
X1-LX
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "2" %}
X-Hybrid
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "3" %}
X1-Hybiyd/Fit
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "4" %}
X1-Boost/Air/Mini
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "5" %}
X3-Hybiyd/Fit
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "6" %}
X3-20K/30K
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "7" %}
X3-MIC/PRO
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "8" %}
X1-Smart
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "9" %}
X1-AC
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "10" %}
A1-Hybrid
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "11" %}
A1-Fit
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "12" %}
A1-Grid
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "13" %}
J1-ESS
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "14" %}
X3-Hybrid-G4
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "15" %}
X1-Hybrid-G4
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "16" %}
X3-MIC/PRO-G2
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "17" %}
X1-SPT
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "18" %}
X1-Boost/Mini-G4
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "19" %}
A1-HYB-G2
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "20" %}
A1-AC-G2
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "21" %}
A1-SMT-G2
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "22" %}
X3-FTH
{% elif state_attr('sensor.qcells_cloud', 'inverterType') == "23" %}
X3-MGA-G2
{% else %}
Unknown
{% endif %}
qcells_cloud_inverterstatus:
friendly_name: "QCells Inverter status"
value_template: >-
{% if state_attr('sensor.qcells_cloud', 'inverterStatus') == "100" %}
Wait Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "101" %}
Check Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "102" %}
Normal Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "103" %}
Fault Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "104" %}
Permanent Fault Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "105" %}
Update Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "106" %}
EPS Check Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "107" %}
EPS Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "108" %}
Self-Test Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "109" %}
Idle Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "110" %}
Standby Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "111" %}
Pv Wake Up Bat Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "112" %}
Gen Check Mode
{% elif state_attr('sensor.qcells_cloud', 'inverterStatus') == "113" %}
Gen Run Mode
{% else %}
Unknown status
{% endif %}
qcells_cloud_uploadtime:
friendly_name: "QCells Update time"
value_template: "{{ as_timestamp(state_attr('sensor.qcells_cloud', 'uploadTime')) | timestamp_local }}"
device_class: timestamp
qcells_cloud_batpower:
friendly_name: "QCells Inverter DC Battery power total"
value_template: "{{ state_attr('sensor.qcells_cloud', 'batPower') }}"
device_class: battery
qcells_cloud_powerdc1 :
friendly_name: "QCells Inverter DC PV power MPPT1"
value_template: "{{ state_attr('sensor.qcells_cloud', 'powerdc1') }}"
device_class: power
qcells_cloud_powerdc2:
friendly_name: "QCells Inverter DC PV power MPPT2"
value_template: "{{ state_attr('sensor.qcells_cloud', 'powerdc2') }}"
device_class: power
qcells_cloud_powerdc3:
friendly_name: "QCells Inverter DC PV power MPPT3"
value_template: "{{ state_attr('sensor.qcells_cloud', 'powerdc3') }}"
device_class: power
qcells_cloud_powerdc4:
friendly_name: "QCells Inverter DC PV power MPPT4"
value_template: "{{ state_attr('sensor.qcells_cloud', 'powerdc4') }}"
device_class: power
qcells_cloud_batstatus:
friendly_name: "QCells BMS Status"
value_template: >-
{% if state_attr('sensor.qcells_cloud', 'batStatus') == "0" %}
Self Use Mode
{% elif state_attr('sensor.qcells_cloud', 'batStatus') == "1" %}
Force Time Use
{% elif state_attr('sensor.qcells_cloud', 'batStatus') == "2" %}
Back Up Mode
{% elif state_attr('sensor.qcells_cloud', 'batStatus') == "3" %}
Feed-in Priority
{% else %}
Unknown status
{% endif %}
# Adding all possible solar strings to one value
qcells_cloud_powerdc_sum:
friendly_name: "QCells Inverter DC PV power sum"
value_template: "{{ states('sensor.qcells_cloud_powerdc1') | float(default=0) + states('sensor.qcells_cloud_powerdc2') | float(default=0) + states('sensor.qcells_cloud_powerdc3') | float(default=0) + states('sensor.qcells_cloud_powerdc4') | float(default=0) }}"
device_class: power
# Calculate house load because this is not part of the Cloud result
qcells_cloud_house_load:
friendly_name: QCells Cloud House Load
value_template: "{{ states('sensor.qcells_cloud_feedinpowerm2') | float(default=0) + states('sensor.qcells_cloud_acpower') | float(default=0) - states('sensor.qcells_cloud_feedinpow
er') | float(default=0) }}"
unit_of_measurement: W
device_class: power
# Battery is being charged
qcells_cloud_battery_charge:
friendly_name: QCells Cloud Battery Charge
value_template: >
{% if states('sensor.qcells_cloud_batpower') | float(default=0) > 0 %}
{{ states('sensor.qcells_cloud_batpower') | float(default=0) }}
{% else %}
0
{% endif %}
device_class: power
# Battery is being discharged
qcells_cloud_battery_discharge:
friendly_name: QCells Cloud Battery Discharge
value_template: >
{% if states('sensor.qcells_cloud_batpower') | float(default=0) < 0 %}
{{ states('sensor.qcells_cloud_batpower') | float(default=0) | abs }}
{% else %}
0
{% endif %}
device_class: power
# Feed to grid
qcells_cloud_grid_feed:
friendly_name: QCells Cloud Grid Feed
value_template: >
{% if states('sensor.qcells_cloud_feedinpower') | float(default=0) > 0 %}
{{ states('sensor.qcells_cloud_feedinpower') | float(default=0) }}
{% else %}
0
{% endif %}
device_class: power
# Load from grid
qcells_cloud_grid_load:
friendly_name: QCells Cloud Grid Load
value_template: >
{% if states('sensor.qcells_cloud_feedinpower') | float(default=0) < 0 %}
{{ states('sensor.qcells_cloud_feedinpower') | float(default=0) | abs }}
{% else %}
0
{% endif %}
device_class: power
# Q-Save 9.1 --> 8300W usable minus 10% minimum load multiplied by soc
# E.g. 35% soc --> 2614.5 W
qcells_cloud_battery_usable:
friendly_name: QCells Cloud Battery usable
value_template: "{{ 8300 * (max(states('sensor.qcells_cloud_soc') | float(default=0) - 10, 0) / 100) }}"
device_class: power
# Solar plus usable battery added
qcells_cloud_solar_plus_battery_total:
friendly_name: QCells Cloud Solar plus Battery total
value_template: "{{ states('sensor.qcells_cloud_powerdc_sum') | float + states('sensor.qcells_cloud_battery_usable') | float }}"
device_class: power
The values for batPower and feedinpower return negative values from the cloud call if battery is discharging or house is loading from grid. As I learned these need to be changed to positive values. That’s what I’ve done in my code above.
After that I did add Riemann sum integral helpers (via GUI) for my own calculated values (Solar, House Load, Battery Charge/Discharge and Grid Load/Feed). I did use “left”, “(k)ilo”, “(d)ay” and “decimal=2” as settings. These integrations are added to the corresponding energy dashboard values.
So - any of your help still very much appreciated. 5 min accuracy is not too bad to beginn with
