Does anyone know if it is possible to get thermostat temperatures through this integration? I do not need to control the thermostat but would love to be able to easily see what the current temperature is.
One way to check for certain if you have the dealer password is when you go to users you’ll see installer password and user password. Do you see that? If you just see the user passwords then you’re using the installer password.
It should be there if you have the dealer password for sure.
This is so strange. I went to my panel to see where it is and it’s actually missing also! I mean I know it’s working the integration is working perfectly fine but I can access the control4 menu anymore… Did they move it or change something?
that’s what I wonder, I have for sure the dealer code, and everything seems to be right, but is not showing there, do you have the IQ REMOTE DEVICE as well?
I don’t understand what’s going on, I do exactly what you said, but I cannot see that option, also, at the options, I can see installer settings, not dealer settings, but the passwords is showing the installer user as you saw in the previous image
Yeah it’s confusing, the instructions I posted above are the correct ones. You definitely need the dealer code not the installer code. I think this is where the confusion started.
I think you are right, I don’t have the correct code, it is 4 digits so I’ll call my provider and see if I have any luck (unlikely), if not I’ll start trying a few codes every day until I find it
Anyway, thank you very much for your help, I think I’m on the right track.
