Qs-wifi-s04-2c
Just taken delivery of one of the newer Tuya modules - the QS-WIFI-S04-2C. This is a dual switch (AC input), dual relay Tuya module. The relays are rated for 5 amps. The module states max load as “2x1150W / 2x150W for LED lamp”
Capture
It tuya converted 1st time without drama and I went straight to ESPHome.
Pinouts are :-
GPIO4 - Buzzer (works with PWM @ 800hz)
GPIO12 - Switch 2
GPIO13 - Switch 1
GPIO14 - Relay 1
GPIO15 - Relay 2
(credit to this youtube video for pinouts https://youtu.be/cBtZAbc9_q8)
The switch work like the dimmer modules - they are a pulsed 50hz AC detection. i.e. - Recieve 50hz pulse (UK AC = 50Hz) when “On”. So I used the same arrangement of a sensor detecting the duty cycle on the GPIO with a template binary sensor tracking the duty cycle > 95%. This has worked very well on the dimmer modules and on initial testing looks to be also effective on these.
ESPHome config for mine… (n.b. change the name and “switch_id” substitutions to suit). I prefer mine to show up in HA as lights only and keep the switches etc as internal.
esphome:
  platform: ESP8266
  board: esp01_1m
  comment: Switch Module 13 (QS-WIFI-S03-2C)
  on_boot:
    priority: -100
    then:
        - output.turn_on: buzzer
        - delay: 250ms
        - output.turn_off: buzzer
        - delay: 250ms
        - delay: 250ms
        - delay: 250ms
        - delay: 250ms
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.111
    gateway: 192.168.1.254
    subnet: 255.255.255.0
# Enable logging
logger:
  baud_rate: 0
  level: DEBUG
  logs:
    sensor: ERROR
    duty_cycle: ERROR
api:
  reboot_timeout: 0s
ota:
web_server:
time:
  - platform: homeassistant
substitutions:
  switch_id: "sw_13"
binary_sensor:
# Template binary switch sensors monitor duty cycle sensors on GPIO pins.
    name: "${switch_id} Switch 1"
    internal: true
    lambda: |-
      if (id(${switch_id}_in_switch1_sensor).state < 95.0) {
        return true;
      } else {
        return false;
# on_click for momentatry (push) switch
# on_state for std rocker switch
    on_click:
      then:
        - light.toggle: ${switch_id}_light_1
    name: "${switch_id} Switch 2"
    internal: true
    lambda: |-
      if (id(${switch_id}_in_switch2_sensor).state < 95.0) {
        return true;
      } else {
        return false;
    on_click:
      then:
        - light.toggle: ${switch_id}_light_2
  - platform: uptime
    name:  ${switch_id} Uptime Sensor
  - platform: wifi_signal
    name: "${switch_id} WiFi Signal Sensor"
    update_interval: 60s
# Duty cycle sensors for switch inputs "S1" and "S2"
  - platform: duty_cycle
    pin: GPIO13
    internal: true
    name: "${switch_id} Switch 1 Sensor"
    update_interval: 20ms
    pin: GPIO12
    internal: true
    name: "${switch_id} Switch 2 Sensor"
switch:
  - platform: restart
light:
  - platform: binary
    name: "${switch_id} Light 1"
    output: "${switch_id}_output_1"
  - platform: binary
    name: "${switch_id} Light 2"
    output: "${switch_id}_output_2"
output:
  - platform: esp8266_pwm
    pin: GPIO4
    frequency: 800 Hz
# Relay Outputs
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO15
Can you please add to esphome-configs.io? Ta.
Dean, I have the same switch and your code works fine. I just have one issue:
when I connect it to power, the relais are turned on, even if I add
restore_mode: ALWAYS_OFF
to the lights. I assume that the duty_cycle sensors are firing on startup. Do you have the same issue?
I am afraid that on every power loss my device is turned on.
Kind regards and thanks for your work!
Hi Christian LIPP,
Were you able to fix the problem?
Can you share the solution?
Best regards!
I used a helper variable, see homeassistant/switch_elias_cover.yaml at f51248d7328aaa164125ad538cea438a69f5707d · ChrLipp/homeassistant · GitHub
But the device did not work as I wanted (the duty detection was not stable) and instead of fixing it I have to admit that I exchanged it with a Shelly 2.5.
When looking at the Shelly esphome code I thought that the same code would also work with this Tuya module but I never tried.
to ensure llights are off when the device starts I added
  - light.turn_off: ${switch_id}_light_1
  - light.turn_off: ${switch_id}_light_2
to the on_boot: section
hope this help
Cheers - Ran
