Question about my knx automation to turn off xiaomi lights
My automation won’t execute, but I do get the command 0/5/4,off in knx, but the xiaomi lights just won’t turn off.
My knx device was added via ui, does it have anything to do with this?
I can’t listen to the 0/5/4 off command in knx_event About my knx automation to turn off xiaomi lights
My automation can’t be executed, but I do get the 0/5/4 off command in knx, but xiaomi’s lights won’t turn off.
I can’t hear the off command from 0/5/4 in knx_event. Question about my knx automation to turn off xiaomi lights
My automation is not working, but I do get the command 0/5/4,off in knx, but the xiaomi lights are not turned off.
I can’t listen to the 0/5/4 off command in knx_event.
Installation
Home Assistant OS
Core
2025.7.1
Supervisor
2025.07.1
Operating System
15.2
Frontend
20250702.1
alias: KNX 离家模式关闭小米灯光
description: 当 KNX 组地址 0/5/4 收到 OFF 指令时,关闭小米的所有灯光和开关
triggers:
- event_type: knx_event
event_data:
address: 0/5/4
type: "off"
trigger: event
conditions: []
actions:
- target:
entity_id:
- light.lemesh_cn_1123993758_wy0a20_s_2_light
- light.mijia_cn_group_1927250626531184640_group3_s_2
- light.lemesh_cn_1123994229_wy0a20_s_2_light
action: light.turn_off
data: {}
- target:
entity_id:
- switch.lemesh_cn_889518281_sw3f13_on_p_3_1
- switch.lemesh_cn_889518281_sw3f13_on_p_2_1
action: switch.turn_off
data: {}
mode: single
