New to both HA and deployment of Docker on a QNAP
First, the installation guide for /alternative/ QNAP must be for the previous version Container Station as many of the fields listed don’t align with Container Station V3.
After a couple guess attempts, the package installed, however I have no idea if it is installed properly ?
Reviewing the help section on Onboarding, regarding section 5 > Check out the devices Home Assistant has discovered on your network. My HA finds nothing after 24 hours, yet I have many of the devices listed as supported for HA (ie ISY, Zwave, Yamaha, etc)
My network is flat and added packages like speedtest to prove connectivity
There is another help doc on Networking and discovery, but I’m lost to understand which file is being edited (and where is this file)
Discovery requires mDNS and is not gauranteed. If devices are notndiscovered you may add them manually
For mDNS to work you need to be using host networking or macvlan. Still, no gaurantee and you may just need to add missing items manually.
Manually add using HA ui >> settings >> devices & services >> add integration. Some integrations cannot be added in ui and must be manually added into the HA configuration file.
If you are able to login and access HA ui, it installed properly.
