It’s time for what was once the simplest way to install Home Assistant to retire.
R.I.P Hassbian
Some of you will probably wonder why Hassbian is being retired and I’ll try to give a proper motivation. First of is the age-old factor of time. I as the lead developer of Hassbian haven’t been able to give it the time and attention it requires, and there have been few others that have pushed the project further. The one exception being @ludeeus who’s done most of the heavy lifting when the image was retooled to use a proper apt package and repository. Second is that it’s no longer the best option for most to use as an installation method. Hass.io has surpassed Hassbian in almost all ways I can imagine.
Next Step for Hassbian
Since Hassbian has been around for quite a while, there are quite a few users that don’t want Hassbian to go away. To make this as easy as possible for those users, here’s the plan.
- The repositories pi-gen and hassbian-scripts hosting the Hassbian projects files will be moved to a new organization.
- A last release will be done by me mid Q4 2019. This image will be hosted under the pi-gen repository.
- The pi-gen repository will be reworked to work with a standard raspbian image with minor modifications for anyone wanting to create their own “Hassbian like” image. This has always been possible, but the current repository is a bit out of date with the current layout of the Raspbian image.
- The hassbian-scripts package will get a final release and will continue to be hosted on Gitlab. Some minor changes will be made to reflect the changes to the project.
Next step for Hassbian users
The Hassbian image has always aimed to be the same as a manual Raspbian Lite installation with some packages added. There won’t really be any big changes for all of the users of Hassbian and for documentation, please refer to the Manual installation on a Raspberry PI method.
Alternatives
If you want to continue using something similar, have a look at the manual installation on a Raspberry Pi since it is the base Hassbian was created from. For everyone else, I would wholeheartedly recommend Hass.io since it what I personally use now (It’s what I had hoped Hassbian could have been but better).
Last but not least
Last but not least, thank you to all of those who contributed, in any way, to the Hassbian project and image.
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2019/10/26/rip-hassbian/
