Could we get Rachio Valve support added to the core rachio integration? It’s a new-ish seemingly popular automatic lawn watering valve. It is not supported by the current Rachio integration.
The Rachio Hoass integration does not seem to support the new Valve product.
I’ve got the rachio integration running, and Hoass is logged into my Rachio account with the correct user/pass combo.
I get this error:
No Rachio devices found in account [email protected]
May 12, 2023 at 11:29:11 AM – (ERROR) Rachio
Hi , @rqbanerjee suggest renaming “Rachio Smart Hose Timer Support”. I have the same issue. Also as suggested by @WallyR please remember to vote for your own suggestion.
I tried to take a look at it but couldn’t find where Rachio devices are defined in the main repo. If someone could point me in the right direction I would be happy to open a PR with the new device.
The smart hose timer doesn’t have API support according to the Rachio forums, so unfortunately there’s nothing that can be done in HA until that happens.
I have a Rachio 3 Sprinkler Controller (4ch) and a Smart Hose Timer with Rachio wifi Hub.
I can see and control both the Sprinkler Controller and the Smart Hose Timer in the iOS an Android apps. I can only see (and control) the Sprinkler Controller on the web portal https://app.rach.io/. I can also only see (and control) the Sprinkler Controller on the Home Assistant integration. The Smart Hose Timer is connected to the Wifi Hub (tested by turning off wifi and bluetooth tablet connectivity and could still control the Smart Hose Timer). @Michael_Borohovski@jmw_ha or anyone else, Can i please ask, do you see the Smart Hose Timer in the web app?
