I have a working automation that my weather station alerts me when it rains and I have a window open.
My problem is that if all windows are closed it states the following.
It is raining and the is open. (NOTICE THE EXTRA SPACE BETWEEN the and is)
How can I get this to state either that xyz window is open or that all windows are closed.
Here is my current automation.
- id: "b8064a7b-6c95-4ec2-a665-c26a0a830cad"
alias: "Rain Alert Window Open"
- platform: numeric_state
entity_id: sensor.5123_weather_event_rain
above: "0"
- service: notify.telegram
message: "It is raining and the {{ dict((states | selectattr('entity_id', 'in', state_attr('group.contact_sensor_windows', 'entity_id')) | list) | groupby('state'))['on'] | map(attribute='name') | list | join(', ') }} is open."
title: Rain Alert Window Open
mode: single
Not at all sure this will work, and there is probably better methods.
message: >
{% set windows = dict((states | selectattr('entity_id', 'in', state_attr('group.contact_sensor_windows', 'entity_id')) | list) | groupby('state'))['on'] | map(attribute='name') | list | join(', ') %}
{% if windows != " " %}
"It is raining and the " ~ {{ windows }} ~ " is open."
{% else%}
"All windows are closed"
{% endif %}
Iām assuming there is a extra space as you said therefore != " "
But you can try the yaml in template editor first to see that it will work
You should avoid using {{ states | .....}} as it reevaluates the template on every entity update. At a minimum use {{ states.binary_sensor | ...}} but expand('group.contact_sensor_windows') is the better way to go.
above: "0"
message: >
It is raining and
{% set ow = expand('group.contact_sensor_windows')
| selectattr('state', 'eq', 'on') | map(attribute='name') | list%}
{%- set qty = ow | count -%}
{%- if qty != 0 -%}
{{-' the '}}{{-' and '.join((ow|join(', ')).rsplit(', ', 1)) }}
{{-' is ' if qty==1 else ' are '}}open.
{% else %} all windows are closed. {% endif %}
mode: single
FWIW, I preferred to have the areas for my notification instead of a long list of window entites.
Area-based template
{% set ow = expand('group.all_window_sensors')
|selectattr('state','eq','on') | map(attribute='entity_id') |
map('area_name') | unique | reject('eq',None) | sort | map('lower') | list %}
{% set qty = ow | count %}
{% if qty != 0 %}
There {{ 'is an' if qty==1 else 'are'}} open window{{' ' if qty==1 else 's '}}in the
{{' and '.join((ow|join(', ')).rsplit(', ', 1)) }}.
{% else %} All windows are closed. {% endif %}
