Raspberry Pi VPN, Socks5 Proxy, Deluge, Jackett, MiniDLNA, Sonarr, Radarr, Lidarr. With USB Hard disk Samba Shares
This all started because i found the deluge sensor in home assistant and had to build my own torrent box but with all the added features i could hope for.
Hope you all like my latest project.
click here for Github wiki
Raspberry Pi + VPN, Socks5 Proxy, Deluge, Jackett, MiniDLNA, Sonarr, Radarr, Lidarr. With USB Hard disk Samba Shares.
Hardware Needed
  • Raspberry Pi 3B
  • USB Hard Drive
Services
  • Samba Share HDD
  • Torrent Server - Deluge
  • DLNA media server - MiniDLNA
  • Movie Torrent Server - Radarr
  • TV Torrent Server - Sonarr
  • Music Torrent Server - Lidarr
  • Torrent Provider Indexer TorzNAB Server - Jackett
  • VPN Secured Internet access for Downloading
  • Additional Netherlands based Socks5 Proxy support in Deluge via PIA
  • Watch Folder to drag and drop torrents into Deluge
Firstly a big thanks to techwiztime for the inspiration and tutorial for how I got this first part working
See:
Setting it up.
Download latest raspberry pi image available from raspbian. I have used in this tutorial Rasbian stretch Lite.
Format SD Card and burn the image using Win32diskimg or Etcher.
Remove SD card from reader and then reinsert card once more to see a list of files on the root of memory card.
Add a new file called ssh (with no extention) to the root of SD.
Insert the memory card into raspi and connect network cable and power in that order.
Login to PI using a SSH client e.g. Terminal or Putty.
sudo apt-get update
sudo apt-get upgrade
I’m using PIA (Private Internet Access) as my VPN of choice. It allows for Socks5 with Auth, really good for deluge and a really solid VPN Provider. See www.privateinternetaccess.com for plans and pricing.
Install Openvpn.
sudo apt install openvpn -y
cd /etc/openvpn
sudo wget https://www.privateinternetaccess.com/openvpn/openvpn.zip
sudo unzip openvpn.zip
cd openvpn
sudo nano login.conf
Add 2 lines,
On the first line: your-vpn-login-user
On the Second line: your-vpn-password
login
Ctrl+x y enter
Modify file permissions.
Sudo chmod 400 login.conf
Copy the ovpn
sudo cp AU\ Sydney.ovpn Sydney.conf
Edit the newly created conf file
Sudo nano Sydney.conf
Look at the file and locate the line < auth-user pass >
Add the login.conf location to this line
auth-user-pass /etc/openvpn/login.conf
Also while in this file add the location of ssl cert by locating the lines < crl-verify > and < ca >
Crl-verify /etc/openvpn/crl.rsa.2048.pem
ca /etc/openvpn/crl.rsa.2048.pem
Ctrl+x y enter
Autostart the vpn at login.
Sudo nano /etc/default/openvpn
Under the last line add
AUTOSTART="Sydney"
Ctrl+x y enter
Reboot pi
sudo reboot
Check the ip of our pi to see if we are connected via VPN
curl ipinfo.io/ip
Your IP should be different from your real exernal ip you can check this by going to another pc and googling whats my ip.
Setup USB HDD for use with raspberry pi. Using EXT4 file system.
sudo parted /dev/sda
Press p
mktable msdos
Yes to continue
Setup EXT parition
mkpart primary ext4 0% 100%
Type p again
See partition on screen
sudo mkfs.ext4 /dev/sda
Y to continue
Create a mount point
sudo mkdir /mnt/torrents
Mount to check
sudo mount /dev/sda1 /mnt/torrents
Check drives mounted
df -h
See dev/sda1 is mounted
Auto mount on reboot
sudo nano /etc/fstab
After the last /dev entry add the following. Try keep formatting with spaces and tabs
/dev/sda1             /mnt/torrents            ext4          defaults      0             0
Ctrl+x y enter
Reboot
sudo reboot
After reboot check to see if the USB HDD automatically booted
df -h
Install and configure Deluge
You can simply install deluge from the terminal using the package manager.
sudo apt-get install deluge
You then need to start the daemon
sudo service deluged start
Then to interact with the daemon using the web ui you must start that
sudo service deluge-web start
Setup Mounts and USB Directories with Deluge.
Create mounts for deluge
sudo mkdir /mnt/torrents/downloading
sudo mkdir /mnt/torrents/completed
sudo mkdir /mnt/torrents/watch
sudo mkdir /mnt/torrents/backups
Open web browser and navigate to http://your-pi-address:8112
Login to deluge with the default password “deluge”
On the webpage Go to.
Preference
Downloads
Add the torrent folders as follows.
Back in putty (terminal) add the following media folders for completed files download from Radarr Sonarr Lidarr
sudo mkdir /mnt/torrents/MEDIA
sudo mkdir /mnt/torrents/MEDIA/movies
sudo mkdir /mnt/torrents/MEDIA/music
sudo mkdir /mnt/torrents/MEDIA/tv
Configure Deluge to Run on Startup
Before we leave the Deluge setup, there is one final detail to attend to. We need to set up the Deluge daemon and WebUI to run automatically when our Raspberry Pi boots up. To do so simply and without the fuss of editing more complicated init files and settings, we’ll simple annotate the rc.local file. Run the following command in a Terminal to do so.
sudo nano /etc/rc.local
With the rc.local file loaded, add the following lines to the end of the file. Note: you do not need to add the the second command ending in “deluge-web” if you are not using the WebGUI. This may also be a good place to add your VPN program, if you’re using one.
Start Deluge on boot:
sudo -u pi /usr/bin/python /usr/bin/deluged &
sudo -u pi /usr/bin/python /usr/bin/deluge-web &
Install Mono
Add the Mono repository to your system
The package repository hosts the packages you need, add it with the following commands.
Note: the packages should work on newer Raspbian versions too but we only test the ones listed below.
sudo apt install apt-transport-https dirmngr
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo "deb https://download.mono-project.com/repo/debian stable-raspbianstretch main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
sudo apt update
sudo apt install mono-devel
The package mono-devel should be installed to compile code.
Install Sonar
Add Sonarr’s repository to your software source
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0xFDA5DFFC
sudo echo "deb http://apt.sonarr.tv/ master main" | sudo tee /etc/apt/sources.list.d/sonarr.list
Install/Update Sonarr
   sudo apt-get update
   sudo apt-get install nzbdrone
Start Sonarr
mono --debug /opt/NzbDrone/NzbDrone.exe
Open Browser http://localhost:8989
Change ownership of NzbDrone folder
sudo chown -R pi:pi /opt/NzbDrone
Startup for Sonarr
sudo nano /etc/systemd/system/sonarr.service
Add the following code.
[Unit]
Description=Sonarr Daemon
After=network.target
[Service]
User=pi
Restart=always
RestartSec=5
Type=simple
ExecStart=/usr/bin/mono /opt/NzbDrone/NzbDrone.exe
TimeoutStopSec=20
[Install]
WantedBy=multi-user.target
Save File CTRL+x y ENTER.
Enable Sonarr service
sudo systemctl enable sonarr
Start Sonarr Service
sudo service sonarr start
Install Radarr
grab the radarr release from here. Copy the link location then go back to PuTTy or your SSH client.
Change directory to /opt
cd /opt
Download the Radarr release.
Sudo wget https://github.com/Radarr/Radarr/releases/download/v0.2.0.1120/Radarr.develop.0.2.0.1120.linux.tar.gz
Extract the release you just downloaded.
sudo tar -xvf Radarr.develop.0.2.0.1120.linux.tar.gz
This will extract the file into a folder called Radarr. Next change ownership of the directory to the pi user.
sudo chown -R pi:pi /opt/Radarr
Startup for Radarr
sudo nano /etc/systemd/system/radarr.service
[Unit]
Description=Radarr Daemon
[Service]
User=pi
Restart=always
RestartSec=5
Type=simple
ExecStart=/usr/bin/mono --debug /opt/Radarr/Radarr.exe
TimeoutStopSec=20
[Install]
CTRL+x y ENTER
sudo systemctl enable radarr
sudo service radarr start
Radarr Will now be accessable on your web browser at http://YOUR-WEB-ADDRESS:7878
MiniDLNA
MiniDLNA is a lightweight media server designed to support the DLNA and UPnP protocols. This works pretty nicely with almost any device you may want to consume media content on and it’s so lightweight it’s an ideal match for the Pi.
So, let’s get started. First, run a full update and then install the minidlna package.
apt-get update
apt-get upgrade
apt-get install minidlna
Once installed, we’ll go ahead and edit the configuration file as follows.
sudo nano /etc/minidlna.conf
media_dir=A,/mnt/torrents/MEDIA/music
    media_dir=P,/mnt/torrents/MEDIA/pictures
    media_dir=V,/mnt/torrents/MEDIA/movies
media_dir=V,/mnt/torrents/MEDIA/tv
friendly_name=Raspberry Pi
    inotify=yes
Fairly self explanitory, I hope. Set your directories, set a name for your media server, and ensure that the media library is automatically refreshed.
Now we start minidlna and we should have a working media server!
sudo service minidlna start
Upon the fist run, the media library will be built. This may take a while depending on how many files you have, once it’s done you shouldn’t have to do it again though.
Finally, ask minidlna to start up automatically upon boot.
sudo update-rc.d minidlna defaults
MiniDLNA streams 1080p to XBoxes, Playstations, Smart TVs and other computers
Install TorzNab Indexer - Jackett
Jackett works as a proxy server: it translates queries from apps (Sonarr, Radarr, SickRage, CouchPotato, Mylar, DuckieTV, etc) into tracker-site-specific http queries, parses the html response, then sends results back to the requesting software. This allows for getting recent uploads (like RSS) and performing searches. Jackett is a single repository of maintained indexer scraping & translation logic - removing the burden from other apps.
Install libcurl
sudo apt-get install libcurl4-openssl-dev
Download and extract the latest Jackett.Binaries.Mono.tar.gz release from the releases page and run Jackett using mono with the command mono --debug JackettConsole.exe.
Mono must be compiled with the Roslyn compiler (default), using MCS will cause “An error has occurred.” errors (See "an error has occurred" trying to load dashboard on QNAP after latest update · Issue #2704 · Jackett/Jackett · GitHub).
Aggregate indexers
A special “all” indexer is available at
 http://localhost:9117/api/v2.0/indexers/all/results/torznab/api
It will query all configured indexers and return the combined results.
To get all Jackett indexers including their capabilities you can use t=indexers on the all indexer. To get only configured/unconfigured indexers you can also add configured=true/false as query parameter.
Set startup
Request server for all users - Ombi
Add the apt repository to the apt sources list:
echo "deb [arch=amd64,armhf] http://repo.ombi.turd.me/stable/ jessie main" | sudo tee "/etc/apt/sources.list.d/ombi.list"
This repo is signed. This means packages get validated before installation. So, to safely download and install Ombi packages the Ombi key needs to be installed:
wget -qO - https://repo.ombi.turd.me/pubkey.txt | sudo apt-key add -
Now update the package list and install Ombi:
sudo apt update && sudo apt install ombi
sudo reboot
If no errors are shown, Ombi has been installed successfully and will automatically start at boot time.
Ombi should now be reachable on
 http://your-ip-address:5000
Packages in this repo use systemd, you can use the systemctl or the service command to start, stop, and restart Ombi.
