stetho
(Steve Thompson)
April 20, 2020, 10:21pm
1
Hi all,
Over the past two (maybe three) days my Netatmo weatherstation has stopped updating in HAss with this message in the logs
pyatmo.exceptions.ApiError: 403 - Forbidden - Application usage reached (26) when accessing 'https://api.netatmo.com/api/getstationsdata'
This seems to imply I’m hitting some sort of rate limit. The Netatmo website rate limit docs say that I can have “200 requests every 10 seconds” so I’m not sure what’s causing this error.
Anyone seen this before? Have Netatmo changed something or have I broken something?
Steve
AlohaDan
(Dan Crevier)
April 20, 2020, 10:52pm
2
I’ve started hitting this too.
cgtobi
(Tobi)
April 21, 2020, 7:07am
3
I’ve noticed this yesterday. I am already investigation quick measures and a long term solution.
Are you using the HA Cloud link or did you setup Netatmo via configuration.yaml
with your own key/secret?
stetho
(Steve Thompson)
April 21, 2020, 7:25am
4
I’m using the HA Cloud. My HA runs as a docker container but I’ve used Configuration > Integrations for anything that doesn’t need tweaking.
cgtobi
(Tobi)
April 21, 2020, 7:31am
5
Until I have a fix the workaround is to use configuration.yaml
. Sorry for the inconvenience.
I have the same problem since last night - Also using the Cloud link.
Do I just add the netatmo-settings to the configuration.yaml or do I have to remove the automatic integration first?
Are there sideeffects on the existing devices or do they stay the same?
cgtobi
(Tobi)
April 21, 2020, 7:41am
7
Yes, right now you have to remove the integration, restart HA and re-add.
Side effects on the existing devices are not known to me and the entities should come back as they were before.
stetho
(Steve Thompson)
April 21, 2020, 10:23am
8
I’m back online with the configuration.yaml solution.
Thanks @cgtobi - It worked as you wrote.
All entities are back online and a in-between-server less…
