I haven’t been able to update my ratgdo instance since early February. It’s stuck on 2024.2.2. Prior to that, I was able to OTA update it without issue.
The logs from an attempt to update via ESPHome Wireless install indicate the following:
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- ArduinoJson @ 6.18.5
|-- Secplus @ 1.0.0+sha.f98c322
|-- EspSoftwareSerial @ 8.1.0+sha.57f1aa7
|-- noise-c @ 0.1.4
|-- Improv @ 1.2.3
RAM: [===== ] 46.2% (used 37844 bytes from 81920 bytes)
Flash: [====== ] 61.3% (used 627953 bytes from 1023984 bytes)
========================= [SUCCESS] Took 11.20 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.0.163
INFO Uploading /data/build/ratgdo-double/.pioenvs/ratgdo-double/firmware.bin (632112 bytes)
INFO Compressed to 422690 bytes
ERROR Error binary size: Error: ESP does not have enough space to store OTA file. Please try flashing a minimal firmware (remove everything except ota)
Why is this an issue now?…Did the ratgdo package increase to a size that is no longer flashable via OTA?
What do I need to do to get it back to being maintainable via OTA?
