Hi guys!
I can’t get razberry 2 work with HA. After many hours playing I managed to find Razberry 2 card with OpenZWave Control Panel. But only partially working. sometimes when I try to initialize it, I can’t get “Home ID” or “Controller mode” for it.
to config.yaml I have added rows like bellow:
zwave:
usb_path: /dev/ttyAMA0
config_path: /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/libopenzwave-0.3.2-py3.4-linux-armv7l.egg/config
but only I can get is error message as bellow:
17-02-26 14:34:06 ERROR (MainThread) [homeassistant.bootstrap] Error during setup of component zwave
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/option.py”, line 75, in init
raise ZWaveException(u"Can’t write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter
for value, tb in values:
File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain
context = exc.context
AttributeError: ‘NoneType’ object has no attribute ‘context’
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/bootstrap.py”, line 152, in _async_setup_component
None, component.setup, hass, config)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/init.py”, line 282, in setup
CONF_CONFIG_PATH, default_zwave_config_path))
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyAMA0 : [‘Traceback (most recent call last):\n’, ’ File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/option.py”, line 75, in init\n raise ZWaveException(u"Can\‘t write to device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception\n return list(_format_exception_iter(etype, value, tb, limit, chain))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter\n for value, tb in values:\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain\n context = exc.context\n’, “AttributeError: ‘NoneType’ object has no attribute ‘context’\n”]’
17-02-26 14:34:17 WARNING (MainThread) [homeassistant.components.sensor.yr] Retrying in 15 minutes:
17-02-26 14:34:32 ERROR (Thread-14) [netdisco.ssdp] Error fetching description at http://192.168.1.250:49152/wps_device.xml
