I am currently moving to home assistant with quite a lot of KNX logics. I have certain group addresses for central-off-functions that will never ever ever ever receive an “on” telegram, but regularly receive “off” telegrams.
I am struggling with reacting to those off telegrams properly, because basically, no status change happens.
What would be the appropriate node to react on every off telegram?
I am currently playing around with the entity settings of the group address (sync_state, ignore_internal_state etc.), but this might even be a bit misleading…
I am just trying to build a flow that only reacts on new off telegrams (only during runtime, not even on startup, because this should not fire the flow).
Hi !
Not sure how this works with node red, but in HA you can use
a binary sensor with ignore_internal_state: true if you need it as entity. This will trigger a state_change event on every telegram (except reads) sync_state: false will disable reads for this entity.
a Knx interface device trigger in an automation
knx_event (see Knx integration documentation “Events”)
a knx.telegram trigger in an automation (from 2024.6 which will be released tomorrow)
Despite having the ignore_internal_state: true and sync_state: false in my KNX config, every reload of KNX config initializes the state and fires my Flow…
you have the GA configured in a *_state_address of another entity
the state restore method of HA triggers the state_changed event (either because of ignore_internal_state or because of it being “unavailable” while reloading)
I’d recommend to not use an entity at all for such things. After all the state isn’t that interesting - it’s always OFF
