Read only sensor/helper display without templates
To make a sensor or helper appear as read only in your dashboard: use the simple-entity type option.
https://www.home-assistant.io/dashboards/entities/#options-for-entities
Combine this with disabling the more-info pop-up (where it could be edited) and you have a read only entity display. e.g.
type: entities
entities:
  - entity: input_number.rain_limit
  - entity: input_datetime.mstr_bed_blanket_on_time
  - type: divider
    type: simple-entity
    tap_action: none
    hold_action: none
    type: simple-entity
    tap_action: none
    hold_action: none
Top two entities are editable, bottom two same entities under the divider are not:
Screenshot 2024-04-20 at 08-58-52 Administration – Home Assistant
Thanks for the tip and explanation.
Nice.
It’s a shame the cursor still changes to make it look like it is actionable though.
