Read Photovoltaic Battery voltage charge
I have the same problem
Please let me know how to fix it
Many thanks!
Let’use Solarman Integration
Reminder: This is an English Language forum. All non English language posts have been removed.
Hi.
Is anyone having issue reading the inverter values via RS485 ModBus?
My inverter work for some days then it stop working. It turns back working after some days also.
Already changed usb dongle.
Also tested with a modbus master software, that report the error “Insufficient data byte received”
Also tried with an ESP32 with rs485 converter, no success.
Dear Andrea,
I added you integration, but on the Energy Tab but most of the variables available within the integration are not avilable…
there is a way to ad statistics data for all variables?
thanks!
Hi there, it seems i can’t find any addresses registry table online. I have two zcs azzurro 3ph 15000tl inverter.
Any help?
Ciao, stavo cercando di fare esattamente la stessa cosa ed ho trovato il tuo post. Per caso hai trovato un modo per poter controllare l’inverter da HA per attivare la modalita’ ricarica da rete in modo programmatico?
Sorry, don’t speak italian so I used auto translate. Hope I got your question:
Yes I did!
I use the action “write multiple holding registers” within the Solarman integration, as the Modbus/USB Stick that sits in my Azzurro HYD 1000 is a rebranded Solarman stick.
Then Someone in a german forum linked me a pdf with all the registers, ages ago. Don’t really find it anymore. But register 4368 is the one that decides the different modes of the inverter. Setting this to “1” is the inverters Time-Scheduled Mode.
Then on the inverter itself I set up this Time-Scheduled Mode to be at 100% everytime.
So if I push that button in Home Assistant, the inverter will start to push the battery to 100%.
I have another button, that uses the same action to set the same register to “0”, then it’s back in the standard self-usage mode.
I remember that it only worked if you use the action for “multiple registers”, even though you only write one.
THAT BEING SAID: I just read minutes ago, that there now is a Sofar Integration from Homeassistant itself and as the Azzurro Inverters are rebranded Sofar inverters, I’d assume that there might be easier ways to do this now. I haven’t tested this yet as it just came out in 2026.09 hours ago.
But maybe this integration will be the way to go from now on.
