I have a different issue , similar challenge where my water meter is outside of the house and accessible to all…not willing to install this in case of burglary etc. The only option I have found is to install a second meter inside the premises that is already equipped with wifi or where I can add wifi/zigbee as above. At the moment too much work for me vs. the gain
Hi, let me share what I am using. Two suggestions:
CHEAPEST & FASTEST - setup ESP32 camera and use the HA built-in seven segment OCR reader ( Seven Segments OCR - Home Assistant (home-assistant.io)) - I’m using that to read a heat meter I cannot get inside access to. This is very sensitive to camera displacement and any dislocation will trip the OCR readings.
MOST RELIABLE - put a bolt-on wireless adapter on you meter / buy a new wireless meter. These operate typically on Wireless MBUS protocols. There is a great addon and super active community for that wmbusmeters/wmbusmeters: Read the wired or wireless mbus protocol to acquire utility meter readings. (github.com)
You’ll need SDR dongle for around $15-20 as well. I am running this setup with 20+ meters non stop for 2 years now. Super, super reliable and stable.
